plugging air ports on 75 heads, I promise I did run a search? |
brant |
Sep 13 2004, 09:27 AM
914 Wizard Group: Members Posts: 11,824 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I know this has been covered repeatedly..
I guess I'm not good at searching... 1) I'm looking for btdt ideas on plugging the air ports on the 75 2.0 motor... 2) also would love to know if I need to readjust the mixture or do anything to the FI after I plug these. thanks in advance brant |
Joe Bob |
Sep 13 2004, 09:30 AM
You can solder them up...or use brass caps available from a hardware store. If I remember...they are standard threads as the injectors were a US required item.
Cap'n Krusty |
Sep 13 2004, 09:40 AM
10x1 mm isn't exactly hardware store stuff. Use the injectors, braze or weld the inlet end. The Cap'n
brant |
Sep 13 2004, 09:49 AM
Do I need to worry about the mixture after I plug them?
brant |
Rhodes71/914 |
Sep 13 2004, 10:35 AM
Glacier Group: Members Posts: 1,374 Joined: 8-August 04 From: End of the Road, Alaska Member No.: 2,482 |
On my '75 2.0L they are brazed closed. Don't have any info for you on mixture but I'll be waiting to hear what others have to say about it.
nebreitling |
Sep 13 2004, 11:16 AM
Member Emeritus Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 |
i found caps at the local ace harware. works fine.
brant |
Sep 13 2004, 11:18 AM
Nathan,
did you need to adjust mixture afterwards? does this even affect mixture (by pumping in all that extra oxygen?) brant |
lapuwali |
Sep 13 2004, 11:41 AM
No, as the air is pumped into the exhaust stream. The idea was the promote more oxidation of any leftover HCs in the exhaust pipe itself. It also assisted in the early style "oxidizing" catalyst used in those days. If you've since swapped to a newer catalytic convertor, then it will be a three-way "reduction" catalyst. If you've removed the cat altogether...
According to at least one emissions engineer I know (guy inside Ford), the air pumps were only useful if the HC level was really high, which should only happen if your mixture was way off, or you where misfiring from ignition problems. In other words, the air pump was only useful if your car needed a tune-up or had some other problem. If your car was in good nick, the air pump was a pretty useless appendage. With a modern catalytic convertor, it's genuinely useless, as the cat by itself will clean up the exhaust tremendously. |
maf914 |
Sep 13 2004, 11:44 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
I think the air nozzles delivered air to the exhaust ports, not the conbustion chamber, to promote additional combustion of the exhaust gases. Their removal should not affect the mixture in the chamber, but emissions are another matter.
nebreitling |
Sep 13 2004, 11:46 AM
nah, you shouldn't need to adjust the mixture.
as long as you're at it, you can rip out the EGR stuff too. be sure to plug any holes (one in exhaust, one to air cleaner box). i picked up a bit more power that way, and the car ran cooler. nate |
Joe Bob |
Sep 13 2004, 12:42 PM
QUOTE(nebreitling @ Sep 13 2004, 09:16 AM) i found caps at the local ace harware. works fine. See Krusty.....told ya. I did the same thing back in ......um, when was it....um brain freeze.... (IMG:style_emoticons/default/headbang.gif) 88 or sumthin'.... :finger2: |
2-OH! |
Sep 13 2004, 01:40 PM
Senior Member Group: Members Posts: 552 Joined: 17-October 03 From: Santa Clarita, Kalifornication Member No.: 1,253 |
I used bolts the same size as the air injectors and no other adjustments are necessary...Loctite, screw em' in and forget um'...Just make sure they are not to long, don't want them to go into the cylinder...
2-OH! |
brant |
Sep 13 2004, 03:08 PM
how long is too long...
Sounds like a 10 metric with a 1.0 pitch... (I can find bolts pretty well, since there is a local place with nearly everything) brant |
2-OH! |
Sep 14 2004, 01:34 PM
Thread in the air injectors, snug em' down, mark with fine tip pen where the head of your bolt will rest...
Remove and measure...subtract a few (2 or 3) millimeters because you do not want to be in as deep as the injectors...should be about 45 mm or there bout's... How's that for scientific... 2-OH! |
94teener |
Sep 14 2004, 01:45 PM
Member Group: Members Posts: 209 Joined: 6-February 04 From: Jacksonville, FL Member No.: 1,636 |
The el-cheapo method is, scew in used 10mm valve adjusting screws.
Phil Attached image(s) |
Tom Perso |
Sep 14 2004, 02:36 PM
Crazy from the Cold... Group: Members Posts: 647 Joined: 8-August 03 From: Kalamazoo, MI Member No.: 1,003 |
10x1x45mm bolts will do the trick...
BTDT. User loctite no matter what you use to block them up. later, Tom |
TheCabinetmaker |
Sep 14 2004, 03:24 PM
I drive my car everyday Group: Members Posts: 8,325 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I used 10 X 55 mm bolts. works great.
Lo-Fi Version | Time is now: 27th December 2024 - 05:44 AM |
