tbox56 |
Member ![]() ![]() Group: Members Posts: 54 Joined: 14-November 04 From: Colorado Member No.: 3,115 ![]() |
I finally put some time into my teener this weekend, and built the mount and shroud for new griffin radiator. I still need to cut a hole for the latch, but other than that it is complete.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i44.tinypic.com-3115-1331537271.1.jpg) |
DBCooper |
14's in the 13's with ATTITUDE ![]() ![]() ![]() ![]() Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California ![]() |
Very nice. You bent those at home?
tbox56 |
914.SBC |
Member ![]() ![]() Group: Members Posts: 248 Joined: 12-December 10 From: CORONA, CA Member No.: 12,479 Region Association: None ![]() |
I love it...
NIcely shaped, etc. (IMG:style_emoticons/default/beerchug.gif) |
firstknight13 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 652 Joined: 25-March 05 From: manchester,ct. Member No.: 3,817 ![]() |
I finally put some time into my teener this weekend, and built the mount and shroud for new griffin radiator. I still need to cut a hole for the latch, but other than that it is complete. (IMG:http://www.914world.com/bbs2/uploads_offsite/i44.tinypic.com-3115-1331537271.1.jpg) why is the bleeder on top ?.....is it a closed radiator?? very nice... (IMG:style_emoticons/default/biggrin.gif) |
Rand |
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None ![]() |
Did I miss the thread on your build that tells about the power plant?
Hoping you'll point me to it or spill the beans. (IMG:style_emoticons/default/wink.gif) Nice metalwork. |
tbox56 |
Did I miss the thread on your build that tells about the power plant? Hoping you'll point me to it or spill the beans. (IMG:style_emoticons/default/wink.gif) Nice metalwork. You didn't miss anything recently, but there might be an old thread somewhere. It is a 2.5l SOHC Subaru engine, naturally aspirated. I am also doing all the body work and paint, adding a set of 916 bumpers, sway bars, and a fresh interior. Should be a sweet ride when it is all said and done. |
Zaney |
Deuchland en der Haus ![]() ![]() Group: Members Posts: 461 Joined: 1-March 04 From: Engine 11 Redmond, WA Member No.: 1,738 Region Association: Pacific Northwest ![]() |
Looks great!
I am in the final stages of my Suby build too. I will watch yours for the body and paint part. Good luck! Cheers! (IMG:style_emoticons/default/beerchug.gif) Nate |
Andyrew |
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California ![]() ![]() |
I finally put some time into my teener this weekend, and built the mount and shroud for new griffin radiator. I still need to cut a hole for the latch, but other than that it is complete. (IMG:http://www.914world.com/bbs2/uploads_offsite/i44.tinypic.com-3115-1331537271.1.jpg) why is the bleeder on top ?.....is it a closed radiator?? very nice... (IMG:style_emoticons/default/biggrin.gif) Because he's smart (IMG:style_emoticons/default/smile.gif) You need a bleeder at the highest points, At the front and the fill in the back are the best spots. |
pete |
Member ![]() ![]() Group: Members Posts: 158 Joined: 23-August 10 From: New Jersey Member No.: 12,092 Region Association: North East States ![]() |
Nice sheet metal work. I'm assuming the radiator mounts are just as nice. Do you have pics of the complete installation? What radiator did you use as I need to start sourcing cooling items for my V8 installation.
Pete |
tbox56 |
why is the bleeder on top ?.....is it a closed radiator?? very nice... (IMG:style_emoticons/default/biggrin.gif) It is a closed radiator, with no pressure valve up front. That is in the back, and as stated bleeders on each end are recommended. And it came that way (IMG:style_emoticons/default/smile.gif) Nice sheet metal work. I'm assuming the radiator mounts are just as nice. Do you have pics of the complete installation? What radiator did you use as I need to start sourcing cooling items for my V8 installation. The mount and shroud is actually one in the same. there are 4 bolts that go through behind the front bumper, and if I feel it is necessary, i can run a couple through the trunk floor as well. The radiator is from Griffin Radiators, found here. I used the 13x22" with the inlet and outlet positioned for my system. It was a little pricy, but very nice, well built, and couldn't fit better. |
firstknight13 |
I finally put some time into my teener this weekend, and built the mount and shroud for new griffin radiator. I still need to cut a hole for the latch, but other than that it is complete. (IMG:http://www.914world.com/bbs2/uploads_offsite/i44.tinypic.com-3115-1331537271.1.jpg) why is the bleeder on top ?.....is it a closed radiator?? very nice... (IMG:style_emoticons/default/biggrin.gif) Because he's smart (IMG:style_emoticons/default/smile.gif) You need a bleeder at the highest points, At the front and the fill in the back are the best spots. i have a griffin radiator and the bleeder is at the bottom but the filler is at the top so i'm wondering if he put the radiator in upside down on purpose with the filler down or if he doesn't have a filler as i do.....i am very much aware of the problems with bleeding the system.... |
Andyrew |
The highest point is engine bay. Your fill and overflow should be in the engine bay..
Lo-Fi Version | Time is now: 25th June 2024 - 05:34 PM |
