DIY lightweight lift parts, or, what I did while 914World was down |
mskala |
May 19 2012, 06:39 PM
R Group: Members Posts: 1,927 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
Okay, for anyone with drive-on lift. The ramps that came with mine
are 1/4" bent steel 18" wide and 47 pounds each. And if you leave them attached while raised, they get in the way of my face (no 12' ceiling for me). So, I bought 'race ramps' which are 4 pound foam bits. But, they are only 3" high when ramp is 4" high, and they need to hook onto the lift. Added a piece of composite decking machined for the hooks, put a bolt thru and done. (IMG:style_emoticons/default/aktion035.gif) Now I can pick these up and throw them anywhere. You can make out the size of the old parts by the marks on the concrete. |
r_towle |
May 19 2012, 07:13 PM
Custom Member Group: Members Posts: 24,680 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
What kind of foam?
I have the big steel ramps also...and they are heavy and hard to store... Formation sells all sorts of foam...wonder if I could just get a slab of foam.... |
mskala |
May 19 2012, 08:07 PM
What kind of foam? I have the big steel ramps also...and they are heavy and hard to store... Formation sells all sorts of foam...wonder if I could just get a slab of foam.... Well, the outside is some kind of formed plastic (with rough texture). When I drilled the hole, it really seemed to come out like tiny (~2mm) styrofoam beads. Without the outer structure and maybe ribs inside, you'd be in big trouble with more than 500 pounds on it. |
euro911 |
May 19 2012, 08:42 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,860 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Nice idea.
(IMG:style_emoticons/default/agree.gif) The ramps that came with my Danmar weigh a ton (not really a ton), but yes, they are fairly heavy boogers. The ramps don't REALLY need to 'hook' onto the lift, do they? |
r_towle |
May 19 2012, 08:51 PM
Nice idea. (IMG:style_emoticons/default/agree.gif) The ramps that came with my Danmar weigh a ton (not really a ton), but yes, they are fairly heavy boogers. The ramps don't REALLY need to 'hook' onto the lift, do they? Without hooking them to the lift, you stand a good chance of shooting a ramp out as you try to get on the lift... |
Cairo94507 |
May 19 2012, 09:01 PM
Michael Group: Members Posts: 10,144 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Nice. I bought the aluminum ramps for my BendPak lift; they weigh 18 pounds each. That's a far cry from the 53 pound stock steel ramps. I can easily hand them on the wall next to the lift above my walking space. I have just shy of a 12' ceiling over my lift.
euro911 |
May 20 2012, 01:35 AM
Nice idea. (IMG:style_emoticons/default/agree.gif) The ramps that came with my Danmar weigh a ton (not really a ton), but yes, they are fairly heavy boogers. The ramps don't REALLY need to 'hook' onto the lift, do they? Without hooking them to the lift, you stand a good chance of shooting a ramp out as you try to get on the lift... Wonder what the scrap value is on those bad boys (IMG:style_emoticons/default/laugh.gif) |
Lo-Fi Version | Time is now: 4th January 2025 - 11:05 PM |
