> Gluing mirror back on, .
etcmss
post May 20 2012, 03:01 AM
etcmss
after replacement of windshield need to attach mirror. tried a couple of adhesives (one was loctite super glue) and neither worked.
what's the best product to attach the mirror?
Replies(1 - 6)
lotus_65
post May 20 2012, 05:39 AM
http://www.914world.com/bbs2/index.php?showtopic=48369
Dave_Darling
post May 20 2012, 05:47 AM
914 Idiot
Your FLAPS sells a rear-view mirror adhesive kit. It works.
--DD
Joe Owensby
post May 20 2012, 09:00 AM
JoeO
You have to make sure both the window and the metal piece are very clean in order to get proper adhesion. Make sure no old adhesive is on either piece before gluing back on. Maybe try a razor blade to scrape the areas and then clean with a cleaner.
euro911
post May 20 2012, 10:25 AM
How coincidental, I just read the factory recall fix ('BC') last night. Loctite # 3325 adhesive is what they recommended. Click Here
post May 20 2012, 11:46 AM
QUOTE(Joe Owensby @ May 20 2012, 08:00 AM) *
Tom_T
post May 21 2012, 05:09 PM
TMI....
(IMG:style_emoticons/default/agree.gif) ...also a final clean with 70-90% rubbing alcohol or adhesive cleaner pads (like the Doctors' offices & hospitals use).
...and the OEM mirror tab is a few bucks (buy 2 - 1 for the next time), cut to proper base size (same for 911/912/930 & 914....others) & the current ones have used the improved 3M or Locktite type adhesive peel-off strips for a few decades now. Enough stick to stay on when surfaces are properly cleaned, but enough foam "peel-off" for NHTSA/US-DOT breakaway requirements in the case of a head hit during an accident.
- Lo-Fi Version Time is now: 4th January 2025 - 09:23 PM
