914World |
Member #1 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 130,681 Joined: 23-December 02 From: World Wide Web Member No.: 1 Region Association: None ![]() ![]() ![]() ![]() |
1972-1973 914 Porsche 1.7L long block.Out of the three engine sizes this is the rare of them that I've found out on some different websites. **It will help to use it for stock motor replacement OR !!! **BUILD BIG it can be built bigger then a VW BUG OR BEETLE MOTOR CAN. IT CAN HANDLE MORE THEN A BUG MOTOR OR BEETLE MOTOR CAN!!! Best thing about it is that it does take much to get it to fit a VW BUG OR BEETLE!** So why start small???
I went by the ENGINE I.D. # to get the correct info on the motor. Its STILL GOOD! I AM ABLE TO TURN IT OVER AND HEAR THE COMPRESSION BUILD UP INSIDE THE BLOCK IN THE BARRELS OF EACH CYLINDER!
View the full article THIS IS NOT A 914WORLD AD! Do not reply to this thread! No one is listening! Click on the "View the full article" link above to go to the actual Ad! |
Lo-Fi Version | Time is now: 26th June 2024 - 12:56 AM |
