can someone show me how this works?, 911 mount |
seanery |
Jun 15 2012, 03:43 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
(IMG:http://www.914world.com/bbs2/uploads/post-6-1163521889.jpg)
I get some of it, but I'm not seeing the whole picture. How does this all fit together? I know that the firewall mount welds to the firewall. I know that the v shaped piece with the arms mounts to the engine. What I don't see, or haven't seen up close and personal is how they mate together. Any help? thanks! |
toolguy |
Jun 15 2012, 03:53 PM
Senior Member Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
just like a stock 911 mount. . .
Andyrew |
Jun 15 2012, 03:56 PM
Big holes in firewall mount are where the motor mounts go. Bolt goes through obvious spot on engine mount.
seanery |
Jun 15 2012, 03:59 PM
so the motor's part of the mount is held under the firewall's mount?
For some reason I always expected it would sit on top. hmm |
Andyrew |
Jun 15 2012, 04:00 PM
To be honest I dont know. I can just see that those pieces go there (IMG:style_emoticons/default/smile.gif)
But based on the design of the motor piece I would say yes, motor piece is on bottom. (Makes sense. Remove bolts, lower engine.) |
toolguy |
Jun 15 2012, 04:11 PM
the rubber cushions go on top of the firewall part. . the long bolts go thru that to the engine part with the nuts on the bottom, so it hangs on the long bolts
SLITS |
Jun 15 2012, 04:26 PM
The big part gets welded to the firewall (bolted if you are lazy). The top of the shelf is mounted 7" above the body seam and centered in the engine bay. If you are using CIS you can drop it to about 6 1/2" to get clearance for the CIS system.
The nose piece (smaller big part) is bolted to the engine. The rubber mounts, sit over the holes in the top shelf and are attached with the short fasteners. Tighten them after the engine is in place as all they do is locate the motor mount. The big washer is placed over the long bolt and dropped through the mount (same as a 911 mounting). This keeps the bolt from pulling through the rubber under weight. I don't see those bolts in your kit, but they are the same as used on the 911 mount. When raising the engine into place, the outer ends of the engine mount are captured by the long bolts. Once in place, washer and nut and tighten. And when you install the engine, you cannot put the front engine tin on as it won't clear the mount. Install after engine is in. Need images? |
SirAndy |
Jun 15 2012, 04:39 PM
Resident German Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
so the motor's part of the mount is held under the firewall's mount? Yes, the engine hangs off the mounts ... (IMG:style_emoticons/default/popcorn[1].gif) |
carr914 |
Jun 15 2012, 04:49 PM
Racer from Birth Group: Members Posts: 119,313 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
seanery |
Jun 15 2012, 04:52 PM
Need images? Thanks for the detailed instructions, Ron! I'll never turn down pictures (IMG:style_emoticons/default/biggrin.gif) *edit* and there it is, TC has a pic to show =) |
seanery |
Jun 19 2012, 10:45 AM
(IMG:http://www.914world.com/bbs2/uploads_offsite/fbcdn-sphotos-a.akamaihd.net-1110-1340123959.1.jpg)
this clears up a bit for me. |
Eric_Shea |
Jun 19 2012, 10:48 AM
PMB Performance Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
SirAndy |
Jun 19 2012, 10:53 AM
this clears up a bit for me. And don't forget the big ass washer on top of that rubber mount ... (IMG:style_emoticons/default/shades.gif) |
Eric_Shea |
Jun 19 2012, 11:30 AM
seanery |
Jun 19 2012, 04:18 PM
that is a big ass washer! (IMG:style_emoticons/default/popcorn[1].gif)
Lo-Fi Version | Time is now: 25th June 2024 - 09:35 PM |
