Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
Hey Gang,
Installing the heater control cable and ran into a problem. Yes, I realize there is a left and a right (longer/shorter etc.) but, after trying both ways it appears the cable is bent wrong from the factory. I'm about 3.5" off each way. Has anyone run into this in the past? Too Short: ![]() Too Long: ![]() |
A&PGirl |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,019 Joined: 4-January 06 From: Oklahoma Member No.: 5,367 Region Association: None ![]() |
That's the same as my new Porsche Cable. The old Porsche is the right length/bend.
I haven't experimented yet with the new cable to make it work. (IMG:style_emoticons/default/popcorn[1].gif) |
Eric_Shea |
So I'm not hallucinating from the brake cleaner fumes.
Maybe Bruce has an original... |
A&PGirl |
Maybe they used a batch of 911 cables and slapped the 914 p/n on it for the 914's to use up stock. Either that or Volkswagen cables.
JimN73 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 535 Joined: 6-October 07 From: Gig Harbor Member No.: 8,192 Region Association: Pacific Northwest ![]() |
I had the same problem and ended up using some other cabling and small cable clamps to make it work. but it's ugly.
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,994 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
Are they equal lengths from the bend? Can you straighten and re-bend?
Eric_Shea |
I was successful in re-bending the original. Had to take 3 5/8" from the long side to the short side. YMMV
tomeric914 |
One Lap of America in a 914! ![]() ![]() ![]() Group: Members Posts: 1,259 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States ![]() ![]() |
I was successful in re-bending the original. Had to take 3 5/8" from the long side to the short side. YMMV Doing a heater pull cable today and ran into the exact same issue as Eric did a year ago. WTF Porsche? (IMG:style_emoticons/default/WTF.gif) |
Cap'n Krusty |
WHAT? If the long side was 3.5" too long and the short side was 3.5" too short, it seems pretty obvious you had the ends reversed.
The Cap'n |
jeffdon |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None ![]() |
Heat? Oh, All that stuff.
Eric_Shea |
tomeric914 |
WHAT? If the long side was 3.5" too long and the short side was 3.5" too short, it seems pretty obvious you had the ends reversed. The Cap'n No... The long side was still longer. It just needed to be balanced a tad more in that favor. Exactly. |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,334 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
I had to rebend mine. Worked perfectly when the passenger side was 2" longer than the driver side. (as per eric's suggestion)
JawjaPorsche |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States ![]() |
I had to rebend mine. Worked perfectly when the passenger side was 2" longer than the driver side. (as per eric's suggestion) (IMG:style_emoticons/default/agree.gif) I had the same problem. Tried it both ways then measured old cable and rebent and it worked. Terry |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
I'm not that anal ... I just clamped the wire in the barrel nut ... it works.
Shame on you Erc ... those aren't real 914/6 flapper valves ... (IMG:http://www.914world.com/bbs2/uploads_offsite/i239.photobucket.com-1696-1368978196.1.jpg) |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,519 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
I'm not that anal ... I just clamped the wire in the barrel nut ... it works. Shame on you Erc ... those aren't real 914/6 flapper valves ... (IMG:http://www.914world.com/bbs2/uploads_offsite/i239.photobucket.com-1696-1368978196.1.jpg) Does this mean Erc is banned from future 914 events until this oversite is corrected? |
TJB/914 |
Mid-Engn. ![]() ![]() ![]() ![]() Group: Members Posts: 4,340 Joined: 24-February 03 From: Plymouth & Petoskey, MI Member No.: 346 Region Association: Upper MidWest ![]() ![]() |
Hey,
I am having the same problem with too long & too short. (IMG:style_emoticons/default/headbang.gif) Dang, jack the car up, crawl under & hook both sides up then crawl back out to check the red lever inside the interior. What the heck, I had the red lever in the wrong position. Should the red lever be moved forward to set the correct tension before I crawl back under the car again??? I need a lift. (IMG:style_emoticons/default/hissyfit.gif) Getting ready for Parade is not fun. (IMG:style_emoticons/default/screwy.gif) Tom |
mepstein |
Hey, I am having the same problem with too long & too short. (IMG:style_emoticons/default/headbang.gif) Dang, jack the car up, crawl under & hook both sides up then crawl back out to check the red lever inside the interior. What the heck, I had the red lever in the wrong position. Should the red lever be moved forward to set the correct tension before I crawl back under the car again??? I need a lift. (IMG:style_emoticons/default/hissyfit.gif) Getting ready for Parade is not fun. (IMG:style_emoticons/default/screwy.gif) Tom Red lever forward. This will create slack on the cable. Tighten barrel nut on the flapper valve. Now when you pull the red lever up and back, you will pull the flapper valve lever and open the heat loop. Passenger side cable should be 2" longer for perfect fit. Lube up cable with light grease before you thread into hard metal tubes in tunnel. If the solid cable end gets stuck in the tube before it exits into the engine compartment, open up the radius of the hard metal tube - just a little bit. |
TJB/914 |
Hey, I am having the same problem with too long & too short. (IMG:style_emoticons/default/headbang.gif) Dang, jack the car up, crawl under & hook both sides up then crawl back out to check the red lever inside the interior. What the heck, I had the red lever in the wrong position. Should the red lever be moved forward to set the correct tension before I crawl back under the car again??? I need a lift. (IMG:style_emoticons/default/hissyfit.gif) Getting ready for Parade is not fun. (IMG:style_emoticons/default/screwy.gif) Tom Red lever forward. This will create slack on the cable. Tighten barrel nut on the flapper valve. Now when you pull the red lever up and back, you will pull the flapper valve lever and open the heat loop. Passenger side cable should be 2" longer for perfect fit. Lube up cable with light grease before you thread into hard metal tubes in tunnel. If the solid cable end gets stuck in the tube before it exits into the engine compartment, open up the radius of the hard metal tube - just a little bit. Thank you, thank you, I am tired of crawling under more than once. Tom |
Drums66 |
914 Rudiments ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region ![]() |
Heat? Oh, All that stuff. ......Go Heat,(Miami) (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/bye1.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 08:34 AM |
