pbob42 |
Newbie ![]() Group: Members Posts: 46 Joined: 6-June 12 From: san diego Member No.: 14,531 Region Association: None ![]() |
Being a newbe is such a pain. Figured out I have the oddball temp sensor with the resistor on top.
Found it toward the back of the passenger side head near cycl 3. What a pain of a location. The wire is busted off. My question is, "how do you get this out?" and "when you get it out how do you get it back in?" |
JeffBowlsby |
914 Wiring Harnesses ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,575 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
Got a photo of what you have?
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
13mm deep socket. Run the wire thru the socket, then insert an extension with one corner ground off for the wire to pass by.
pbob42 |
pbob42 |
13mm deep socket. Run the wire thru the socket, then insert an extension with one corner ground off for the wire to pass by. Got it out - what a chore - where do I send Christmas cards to the designer of this? Thanks for the heads up. Where can I get one of these? |
pbob42 |
13mm deep socket. Run the wire thru the socket, then insert an extension with one corner ground off for the wire to pass by. Got it out - what a chore - where do I send Christmas cards to the designer of this? Thanks for the heads up. Where can I get one of these? Anders says the 1.7 sensor or the 2.0 sensor from others years will work. Is this correct? |
pbob42 |
OK - figured it out - use the 1.7 L cht from '73 and throw in a 270 ohm balast resistor.
Lo-Fi Version | Time is now: 26th June 2024 - 04:05 AM |
