ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
I'm making these to go with our new repair kits, but they are available separately.
Special price valid thru 7/31. ![]() The hollow hex tool is double ended because I've found adjustment screws with significantly different tool fitment. The tool which fits the smaller screw just spins inside the larger screw. The size difference is quite small, but significant nonetheless. ![]() I've decided to make the full load stop screw with a thru-hole so the unit can be properly adjusted without removing the stop screw. A vinyl cap is included to protect the screw after making adjustments. ![]() ![]() |
pbanders |
Senior Member ![]() ![]() ![]() Group: Members Posts: 939 Joined: 11-June 03 From: Phoenix, AZ Member No.: 805 ![]() |
That's 'frikin' nice. How much? I made my own with some brass tubing, but yours is better.
ChrisFoley |
That's 'frikin' nice. How much? I made my own with some brass tubing, but yours is better. $42.95, delivered - thru July. The two kits together are $132.95 right now. I made a minor adjustment to my process between the first prototype and the start of production and I'm real happy with how the tool shape is coming out. It fits so good it seems to have eliminated the need for two slightly different sizes. |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,517 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
Chris, I'm one of those that will order 2 at the last minute. But only 1 tool kit. Slow 2nd Qtr. (IMG:style_emoticons/default/sad.gif)
Lo-Fi Version | Time is now: 25th June 2024 - 12:30 AM |
