kbrunk1 |
Brunk ![]() ![]() Group: Members Posts: 180 Joined: 13-November 11 From: Dallas,Texas 73 2.0 FI Member No.: 13,778 Region Association: South East States ![]() |
Found SAE 5/16 30R9 for $4.00 per foot at autozone. I was going to spend $100 at Atlanta Parts for the "kit" but now am wondering if all of these have to be R9
They have 30R7 and most seem to be the size of 5/16. Am I off base here? I do not care about colors.... Are the other off sizes hard to get? Are they not all near the 5/16 size? What is everyone using? |
CG-914 |
Member ![]() ![]() Group: Members Posts: 326 Joined: 27-December 10 From: LA/OC CA Member No.: 12,526 Region Association: Southern California ![]() |
depending on the year and the FI you have different diameters!
Sometimes even with one and the same car! R9 is what you should use at least! R10 is very very pricy but rated for that horrible (IMG:style_emoticons/default/ar15.gif) ethanol... But atlanta is usually more expensive therefore you find some parts you dont find somewhere else! What model do you got? |
CG-914 |
JeffBowlsby |
914 Wiring Harnesses ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,550 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
Please clarify which lines you are referring to, the word 'vapor' is confusing to me. 914s have fuel lines (fuel only), and vacuum lines (air only). Some of the vacuum lines carry vapors, but they are technically called vacuum lines.
Let us know what you need and we can chime in. PS: Use only the metric hose...not the english-unit sizes. |
kbrunk1 |
Please clarify which lines you are referring to, the word 'vapor' is confusing to me. 914s have fuel lines (fuel only), and vacuum lines (air only). Some of the vacuum lines carry vapors, but they are technically called vacuum lines. Let us know what you need and we can chime in. PS: Use only the metric hose...not the english-unit sizes. Vacuum lines. ( I have bought SAE30R9 fuel injection hose 5/16.) |
JeffBowlsby |
The fuel hose spec is more than fine for vacuum purposes, but I am not sure which lines you'll use that size for, that 5/16 is not applicable to much in the engine bay and should not be used for the fuel lines. Here are the vacuum line specs for the late 1974 2.0L, all of it is identical to your 73 2.0L except the charcoal filter plumbing and the second line to the throttle body from the vacuum advance. And I also attached the 1973/2.0L version.
Attached image(s) ![]() ![]() ![]() |
kbrunk1 |
What size should fuel line be?
I just relocated my fuel pump under the tank and used a 5 piece kit with 8mm stainless lines down the tunnel. and two 8mm risers to the rails. Your drawing is nice and it is correct (Dave Darling's), however according to Automotive Atlanta they no longer make 13mm vacuum lines and they only sell 12mm in the US. Is this bad info? I was also told that 5/16 SAE 30R9 was the best for ethanol fuel injection lines. Am I going down the wrong path? They seem to fit nicely on the fuel pump and down the rails (8mm)? |
Lo-Fi Version | Time is now: 18th June 2024 - 07:59 AM |
