What oil does everyone run?, Not just break in oil! |
tscrihfield |
Aug 5 2012, 04:19 PM
Drive Fast and Take Chances Group: Members Posts: 643 Joined: 8-September 10 From: Amelia Ohio Member No.: 12,156 Region Association: None |
Okay I did a search on oils that people run and my search was less than helpful. I always get the same thing. Brad penn oil... I know that this is good oil and many run this but I would like to know what everyone runs.
So please state the engine your running and what oil you're running. Thanks, Thomas |
ConeDodger |
Aug 5 2012, 04:27 PM
Apex killer! Group: Members Posts: 23,645 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
(IMG:style_emoticons/default/evilgrin.gif) In my 2432 Raby Motor, I run - you guessed it, Brad Penn 20W - 50 Racing Oil...
I do not Fuch around with this motor. It's worth more than the car cost new! |
billh1963 |
Aug 5 2012, 04:29 PM
Car Hoarder! Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States |
2.0's and 1.7...Brad Penn
GeorgeRud |
Aug 5 2012, 04:42 PM
Brad Penn or Raby's new oil are safe bets. I've also heard that Kendall GT is once again available, that's what our local Porsche guru is recommending.
jsayre914 |
Aug 5 2012, 04:47 PM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
2056 d-jet Brad Penn 20-50
Got a case from Chris (Tangerine) Thanks Chris (IMG:style_emoticons/default/beerchug.gif) |
Elliot Cannon |
Aug 5 2012, 04:56 PM
MOBIL 1 10/50. (Ceramic lifters). (IMG:style_emoticons/default/wub.gif)
TheCabinetmaker |
Aug 5 2012, 05:12 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
2056/9550 cam. Brad Penn. Have a hot rod shop a mile away that carrys it
Porschef |
Aug 5 2012, 05:19 PM
How you doin' Group: Members Posts: 2,170 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
2056 d-jet Brad Penn 20-50 Got a case from Chris (Tangerine) Thanks Chris (IMG:style_emoticons/default/beerchug.gif) Likewise |
Java2570 |
Aug 5 2012, 05:35 PM
Senior Member Group: Members Posts: 649 Joined: 7-May 11 From: Fishers, IN Member No.: 13,035 Region Association: Upper MidWest |
In my '74 2.0L I run Brad Penn 20w50 in hot months, 10w40 in colder weather.
Mark Henry |
Aug 5 2012, 07:04 PM
I've run the Swepco oil with no issues, about the same price as BP (a local source for BP only just came available) but it's delivered to my door.
Black22 |
Aug 5 2012, 07:28 PM
Senior Member Group: Members Posts: 886 Joined: 1-November 07 From: Creswell, OR Member No.: 8,290 Region Association: Pacific Northwest |
1911 w/ L-jet...Brad Penn 20/50
bembry |
Aug 5 2012, 07:35 PM
Senior Member Group: Members Posts: 529 Joined: 29-July 05 From: Bakersfield, CA Member No.: 4,499 Region Association: MidAtlantic Region |
2056 by McMark with dual webers--Bard Penn 20W-50
914itis |
Aug 5 2012, 07:44 PM
Advanced Member Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
Stock 1.0 and 1.7 both brad penn
michael7810 |
Aug 5 2012, 07:45 PM
Senior Member Group: Members Posts: 1,081 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
BP 20-50 but just ordered a case of Joe Gibbs DT50 to see if the oil runs cooler.
ww914 |
Aug 5 2012, 08:17 PM
914 Convert Group: Members Posts: 435 Joined: 29-September 11 From: Central Coast, CA Member No.: 13,621 Region Association: Central California |
BP in a McMark 2270. No comments yet. The engine is brand new.
tscrihfield |
Aug 5 2012, 08:35 PM
WOW! Now I understand why all I would see is BP!
Okay, Are the benefits due to the Zinc? What sources do you use to obtain the oil? Thanks for everyone's input! Thomas |
Rand |
Aug 5 2012, 08:55 PM
Zinc and phosphorus are the key ingredients. (Make sure it's the green stuff - BP has some other formulas that aren't right for our engines.)
I get mine at the local Summit Racing outlet. FWIW I documented the results of my research here: http://randbaldwin.com/?p=326 |
monkeyboy |
Aug 6 2012, 08:39 AM
Senior Member Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None |
I have been using Lucas Hot Rod oil. 20-50 synthetic with high zinc and phosphorus.
I am due for an oil change so I will be trying the Gibbs DT-50. |
StratPlayer |
Aug 6 2012, 09:38 AM
StratPlayer Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
Brad Penn 20 50
Randal |
Aug 6 2012, 09:52 AM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
Kendall with liquid titanium, GT-1
Been running this 30 weight oil since my 2414cc race motor was built. About 5 hours on the motor between autoxing and hill climbing. |
Lo-Fi Version | Time is now: 30th June 2024 - 10:23 PM |
