Strudelwagon |
Member ![]() ![]() Group: Members Posts: 411 Joined: 11-October 08 From: interior, British Columbia Member No.: 9,633 Region Association: Canada ![]() |
So my 3 year project is on the road...first 914 i have ever owned so maybe this is normal???
when I put my turn signal on (74-2.0) the little green light on the tach flashes. when it self cancels, sometimes the green light stays on steady. If I move the signal lever a little it goes off??? just the little light not the actual signal lights on the corners any idea? (IMG:style_emoticons/default/confused24.gif) SW |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
This is the classifieds. You'll get more exposure in the garage. Am admin will move it for you shortly
Strudelwagon |
This is the classifieds. You'll get more exposure in the garage. Am admin will move it for you shortly OOPS Thanks.....Are you the REAL cabinetmaker? (IMG:style_emoticons/default/happy11.gif) |
TheCabinetmaker |
The one and only!
euro911 |
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California ![]() ![]() |
Not the Cabinetfaker (IMG:style_emoticons/default/confused24.gif)
TheCabinetmaker |
No. The faker is history, but my guess is he'll be back. He's probably back already. Skulking around under a different name. Andy knows who he is and keeps an eye on him. Thanks Andy and all the admin.
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
Before you troubleshoot anything, do this...
Disconnect battery remove fuse panel under dash find ground stud remove nut and clean all terminals with wire wheel or emery cloth replace all grounds, nut and tighten replace fuse panel reconnect battery Now what is your car doing? Same thing? if so check all the ground connections behind the gauge cluster. test again... |
Strudelwagon |
Before you troubleshoot anything, do this... Disconnect battery remove fuse panel under dash find ground stud remove nut and clean all terminals with wire wheel or emery cloth replace all grounds, nut and tighten replace fuse panel reconnect battery Now what is your car doing? Same thing? if so check all the ground connections behind the gauge cluster. test again... Sorry mike, this was moved after I reposted. I'll get that fuse box out and follow your instructions. I figured it might be a ground...years ago I owned British cars and the solution in most cases was the same Cheers |
Strudelwagon |
Strudelwagon |
Before you troubleshoot anything, do this... Disconnect battery remove fuse panel under dash find ground stud remove nut and clean all terminals with wire wheel or emery cloth replace all grounds, nut and tighten replace fuse panel reconnect battery Now what is your car doing? Same thing? if so check all the ground connections behind the gauge cluster. test again... Sorry mike, this was moved after I reposted. I'll get that fuse box out and follow your instructions. I figured it might be a ground...years ago I owned British cars and the solution in most cases was the same Cheers I love blackberry. Playbook (IMG:style_emoticons/default/headbang.gif) |
Strudelwagon |
OK Mike,
I cleaned the ground post under the fuse panel and the signal indicator light still stays on some times after it cancels. Is it a short in the column switch? (IMG:style_emoticons/default/confused24.gif) Is it time to rip the column apart? Thanks Steve |
Strudelwagon |
timothy_nd28 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest ![]() ![]() |
When this indicator light stays on, does the turn signals illuminate as well? I had this issue earlier, ended up being the contacts within the turn signal stalk.
Go ahead and buy a new turn signal stalk. They are selling these new for only 23 dollars. |
timothy_nd28 |
Strudelwagon |
You Da Man Tim....Thanks (IMG:style_emoticons/default/pray.gif) |
Mike Bellis |
Could be a bad flasher relay too. The flasher relay is a dual semi-electronic relay. It has one relay dedicated to the exterior lamps and one for the dash lamp. It is possible for half the relay to go bad. Relay failure can be accelerated by adding LED lamps to the turn signals. Replacement relays are available for around $50. Plug and play.
Lo-Fi Version | Time is now: 26th June 2024 - 12:42 AM |
