> Does this gauge fit the stock sender
jsayre914
post Aug 26 2012, 03:42 PM
Speed Up !!!
It dosent say that it comes with the sender?
Will this work on a stock 1973 2.0 in place of the original gauge.
Same wires? Could it be plug and play?
LINK
Replies(1 - 3)
Black22
post Aug 26 2012, 03:54 PM
I'm not sure what is considered a stock sensor, but I do know that there are different valued senders out there. A 200C sender will read differently than a 150C sender.
Google a sender that is for use with that particular gauge.
Go to eGauges.com
Pick that VDO gauge and it will have a link to all the senders that work with it. For the Taco plate it looks like p/n 323-055. Which is a 150C/300F value sender. The taco plate is a 14mm thread IIRC.
Verify first though.
Dave_Darling
post Aug 26 2012, 09:02 PM
914 Idiot
It should work, as in "give you a reading".
It will probably read wrong, though. Depends on the resistance range that the gauge expects and the resistance that your sender gives you. They might match, but there's a good chance they won't.
--DD
gothspeed
post Aug 27 2012, 02:55 PM
When I bought one of those VDO oil temp gauges and its matching sender ........ the sender that was already in the taco plate ..... was exactly the same part # as the one I bought ........ so I swapped them just in case the old one was tired.
- Lo-Fi Version Time is now: 31st October 2024 - 07:23 PM
