No Power to Fuel Pump ? |
kbrunk1 |
Sep 28 2012, 11:02 AM
Brunk Group: Members Posts: 180 Joined: 13-November 11 From: Dallas,Texas 73 2.0 FI Member No.: 13,778 Region Association: South East States |
OK - Still on blocks.
Moved fuel pump to under tank. I am a pretty good sparky and moved the "fuel pump plug" with ample wire size to extend it to the front under the tank. I soldered it after cutting the "electric plug" from tne back to the front and used lots of shink wrap. Tanks is back in with 1.5 gallons of fuel. I am 99.9 certain it is not a broken wire from the engine bay to under the tank to pump. I check continuity on all fuses under the steering wheel. I electric drill wire brushed the brown grounds by the heater fan and circuit board at that point. Hooked up test 12 volt light on "electric plug" Light flashes when you turn on the key and then the light goes out and you hear a click.....?? Any help here? Not sure here.....Help! |
underthetire |
Sep 28 2012, 11:19 AM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Fwiw the fuel pump fuse is on the relay board, along with the fuel pump relay.
kbrunk1 |
Sep 28 2012, 12:06 PM
Hooked up 12V light to termnal of pump.
When you turn the key on the light comes on for a second and then kicks off. You can hear a "click?" |
dlee6204 |
Sep 28 2012, 12:31 PM
Howdy Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
It sounds normal. With D-jet, when you turn the key to the on position, the pump will run for a brief second and then go off. When cranking/running the pump will stay on.
Tom |
Sep 28 2012, 12:56 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
(IMG:style_emoticons/default/agree.gif) with dlee.
For D-jet, the pump runs one of three times, 1- upon initial key to on for about 1.5 seconds. 2- when starter is engaged, 3 when engine rpm's exceed XXX rpms. Tom |
SirAndy |
Sep 28 2012, 12:58 PM
Resident German Group: Admin Posts: 41,972 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
If the D-Jet brain is not plugged in, the pump will not get any power ... (IMG:style_emoticons/default/popcorn[1].gif) |
Lo-Fi Version | Time is now: 14th January 2025 - 10:46 PM |
