Allan |
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California ![]() |
What is the best way to clean all of old permatex from the the sealing surfaces of the engine cases before re-assembly without taking away any of the metal. I don't want to create uneven areas that could lead to leaks.
Carrera916 |
Member ![]() ![]() Group: Members Posts: 292 Joined: 9-February 03 From: Pleasanton, CA Member No.: 273 ![]() |
I usually spray a bit of carb cleaner on the edge of case to let the old glue soften up a bit.....I have a tri-blade scrapper that I always use to scrap the old glue out without shaving any metals off....maybe a couple on subborn areas (IMG:style_emoticons/default/wink.gif)
Then do it again with the carb cleaner and clean white rag to go over the edge, it should come right out... j |
URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 121,302 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
Carb cleaner is the universal cleaner.
Also scrape it with a stright blade razor. |
Allan |
So stay away from brass brushes or scotch brite?
kermit |
Member ![]() ![]() Group: Members Posts: 169 Joined: 2-November 04 From: Millbrae, CA Member No.: 3,049 ![]() |
This is basically what I did when I rebuilt my motor, but it still drips some oil.
Depending on your funds, you may want to consider line boring the cases by a machinist. Any thoughts on this out there? |
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
QUOTE(Headrage @ Nov 4 2004, 04:36 PM) So stay away from brass brushes or scotch brite? I use a scotch brite disc on my air grinder after scraping all the heavy residue. |
Lo-Fi Version | Time is now: 26th June 2024 - 03:01 PM |
