cary |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest ![]() ![]() |
Taking a time out on my rustoration project.
Decided to tackle my problem with the engine lid hinge on my other car. Late last summer I found the hinge was coming away from the body. Hinge wasn't cracked. Spot welds were still intact. The damn firewall had cracked. Right above the top spot welds. (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/sad.gif) ![]() ![]() |
cary |
The extra hole was a feeble attempt at tightening it up last summer.
Tried a self taping screw. Didn't work Couldn't see the crack until the hinge was taken off. Man that is some thin metal ..................... Going to put in a patch. Left the shop with the weld thru primer drying on the work bench. I don't understand why the metal is so thin. I assume it has sometime to do with forming the ridges in the firewall. |
partwerks |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 ![]() |
Ridges would probably be to stiffen up the sheet metal.
aharder |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,428 Joined: 6-September 11 From: Dallas Texas Member No.: 13,524 Region Association: Southwest Region ![]() ![]() |
J West has the set up (IMG:style_emoticons/default/biggrin.gif)
http://www.jwesteng.com/porsche/914/ |
zambezi |
Senior Member ![]() ![]() ![]() Group: Members Posts: 711 Joined: 14-April 08 From: Lafayette, LA Member No.: 8,920 Region Association: South East States ![]() |
I see a trunk hinge setup but i don't see anything for the engine lid from Jwest. Am I missing something?
jimkelly |
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region ![]() |
i don't think the engine lid brackets go bad very often.
jwest only has a trunk hinge repair kit. Attached image(s) ![]() |
cary |
I think we'll attach the patch on top to tie it all together.
No way to access to butt weld. Might need to shorten the lid side of the hinge a smidgen to get the perfect fit. Or length the slot. |
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,735 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
If you overlay the metal it would push the engine lid rearward, and close the gap between the trunk lid, so slotting the holes is a good idea.
That's a tough place to fix. The two layers of metal and the bends in that top section make it a challenge. Have you tried a Blair Rotabroach? They make the best spot weld cutter. Not the cheapest spot weld cutter, but they last much longer and are faster and easier to use. http://www.blairequipment.com/Rotabroach_C...ta_cutters.html |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
i don't think the engine lid brackets go bad very often. I dis-agree ... I see them fail all the time, they usually crack either at the 90 degree bend or the firewall itself cracks near the spot welds. This is *very* common! While you are in there, add a bit of metal right at the 90 degree bend on the hing to give it a bit more strength in that area. (IMG:style_emoticons/default/welder.gif) |
mr914 |
914 Hillbilly ![]() ![]() ![]() Group: Members Posts: 576 Joined: 11-January 03 From: Lincoln NE Member No.: 131 Region Association: None ![]() |
Where is it common to crack?
I'm having an alignment issue on my '71. Stiffened the hinge with a little weld bead this summer. Still the one side is 1/2" too far out |
Jgilliam914 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,328 Joined: 30-July 12 From: Iowa / Florida Member No.: 14,732 Region Association: Upper MidWest ![]() |
i don't think the engine lid brackets go bad very often. I dis-agree ... I see them fail all the time, they usually crack either at the 90 degree bend or the firewall itself cracks near the spot welds. This is *very* common! While you are in there, add a bit of metal right at the 90 degree bend on the hing to give it a bit more strength in that area. (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/agree.gif) I am in the process of welding 2 new hinges on mine. IMO one hinge becomes weak and puts the other in a bind then both are in the same shape.I thought welding up the weak areas in them but decided to replace them both. I bought them years ago and saw them when I moved this past summer and damned if I can find them now (IMG:style_emoticons/default/chair.gif) But I do have the area all prepped whenever I do find them |
cary |
Have you tried a Blair Rotabroach? They make the best spot weld cutter. No, but those where cut with my new set of Rotacut sheetmetal cutters. http://www.hougen.com/cutters/sheetmetal/Rotacut.html Trying to make smaller holes, broke the 1/4 inch one off in the first hole. (IMG:style_emoticons/default/sad.gif) (IMG:style_emoticons/default/sad.gif) I hate to say they work a bit better than the HF one. LOL. |
cary |
cary |
cary |
cary |
cary |
Here's it installed and covered with self etching primer.
Waiting for the primer to dry. Then I'll seam seal the top and sides. I'm pretty certain lack of weld thru primer was the culprit. Didn't grind the welds up tight. Might have issues with the other side in the future and may need to remove to get a CW alignment. Right now the lid is just a little lower than the two sides. ![]() |
cary |
Lo-Fi Version | Time is now: 25th June 2024 - 08:48 PM |
