Engine swap: 2.0 - 3.2 |
GulleyGulley |
Dec 27 2012, 11:22 AM
Member Group: Members Posts: 67 Joined: 12-March 12 From: CNY Member No.: 14,243 Region Association: None |
I'm getting close to pulling the trigger on a 3.2 for my 914-6. Car currently has a 2 liter original 6 in it with webers. This engine will be for sale later this winter. It's not original to the car (it was a 4 banger) so I'm not worried about authenticity. Couple of questions for those that have installed a 3.2
1) Can I use the flywheel & starter from the 2.0 (installing new clutch) 2) What mods need to be done to the stock tranny housing. Anyone have a picture 3) Keeping the stock oil cooler, lines, etc. 4) Running new fuel lines for supply & return 5) Any other "while I'm in there" |
Cupomeat |
Dec 27 2012, 11:50 AM
missing my NY 914 in VA Group: Members Posts: 1,338 Joined: 26-November 07 From: Oakton VA Member No.: 8,376 Region Association: MidAtlantic Region |
A couple of thoughts regarding your conversion;
1) Can I use the flywheel & starter from the 2.0 (installing new clutch) Not sure it fits (don't think it does), but if you are using the Motronic FI from the 3.2, you'll need the 3.2 one (see #2) 2) What mods need to be done to the stock tranny housing. Anyone have a picture If you are keeping the Motronic FI, you'll need to cut a notch in the housing for the crank position sensor (Hall sensor that acts off the flywheel) 3) Keeping the stock oil cooler, lines, etc. Ok, but I recommend getting a ducted front cooler as you'll need it with such a big engine. |
sixaddict |
Dec 27 2012, 11:52 AM
Senior Member Group: Members Posts: 869 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States |
Can answer some but Sir Andy has it all
Flywheel clutch is a big No......Kennedy engineering good source cD box changes Better consider aux oil cooler if you don't have on If headers need bigger diameter Assume Fuel injection not carbs Haven't checked but most likely there are threads May answer all questions and more On trans it will work if you don't brutaliz it but heavier axle/cv joints may be good idea Or some say leave stock and break cvs not transmissions (IMG:style_emoticons/default/evilgrin.gif) (IMG:style_emoticons/default/evilgrin.gif) (IMG:style_emoticons/default/evilgrin.gif) |
Cap'n Krusty |
Dec 27 2012, 11:56 AM
Don't forget the tach. You'll need it with the 3.2 engine management system.
The Cap'n |
GulleyGulley |
Dec 27 2012, 12:26 PM
Thanks!
- Forgot about the tach. - Yes, planning on an additional cooler. I'm going to try & keep it in the back area. I don't want to modify the front trunk. Maybe in the front wheel well like on the 911's. - Have a price request into in Kennedy - Have the stock engine computer etc. with the new 3.2 |
MoveQik |
Dec 27 2012, 02:25 PM
What size wheels can I fit? Group: Members Posts: 4,654 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region |
3) Keeping the stock oil cooler, lines, etc. Ok, but I recommend getting a ducted front cooler as you'll need it with such a big engine. FWIW, I have the 3.2 in mine with the cooler under the rear trunk. Works fine even in our AZ heat. I didn't want to cut up the trunk if I didn't need to. |
jim912928 |
Dec 27 2012, 04:00 PM
Senior Member Group: Members Posts: 1,487 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
Do a search on my screen name and you'll find my threads on wiring a 3.2 and running fuel lines front to back (you'll also need the 3.2l fuel pump). Need the 3.2l fly wheel but you'll need the conversion ring gear so the starter engages. The 914 parts places will sell you the conversion kits (Kennedy stuff). In one of my 3.2l threads I have a pick of the transmission cutout.
Lo-Fi Version | Time is now: 4th January 2025 - 07:47 PM |
