> Repro Center Caps for Alloys
Mike Fitton
post Dec 29 2012, 09:53 PM
Bought some reproduction center caps for the 914 Alloys (mine are Mahle's), they are ISP brand available at: vwispwest.com. They look great and are made of thicker metal so they won't dent but I am having trouble getting them to go on since they are friction fit like originals but don't give as much. Does anyone have a solution maybe cut 3 vertical slits into the sleeve so there is some give. Let me know if you have installed these on your car. Thanks!
Replies(1 - 8)
Socalandy
post Dec 29 2012, 09:56 PM
Its got to be Yellow!!!
I had some, they told me to use WD40 and a rubber mallet. Worked great but have tires and balance done first.
914Sixer
post Dec 29 2012, 09:57 PM
Seems like someone got a piece of plastic pipe the diameter of the lip and slipped it over the center and popped in on with a rubber hammer.
reharvey
post Dec 29 2012, 10:34 PM
I had to cut six slits into mine to get them on without using a sledge hammer. Ray
Gint
post Dec 29 2012, 10:39 PM
Mike Ginter
You're not the first guy that I've heard about having issues with those caps fitting.
Didn't Mikey914 make a run of repro center caps? Seems like a I bought a set. Don't know where they are, and haven't tried them yet.
post Dec 29 2012, 11:12 PM
I have Mikey's and had to cut slits, also. They fit tighter than bark on a tree and look nice.
Mikey914
post Dec 31 2012, 02:52 PM
The rubber man
Mine come with the slits cut into them. You may want to check the clearance on the front caps you bought I heard they too had issues with fitment on the front wheels. I solved this problem, hopefully they did too.
bigkensteele
post Dec 31 2012, 03:06 PM
Major Member
I have Mark's on my Mahles, and they look great! To me, the satin finish looks much better than the original.
Mine were very tight, so I had to use a rubber mallet. I think that this is partially due to the fact that my wheels have been painted at least once. Someday, I plan to take them off and sand the inside of the center holes to make the caps fit better.
JawjaPorsche
post Dec 31 2012, 03:13 PM
Got mine from Mark. Put some grease on the wheel hole and had no problem.
- Lo-Fi Version Time is now: 26th December 2024 - 10:05 AM
