> Clutch cable heat protection, Clutch cable heat protection
1845
post Dec 30 2012, 01:32 PM
Anyone have a line on a clean heat sheild product that you can put around the clutch, accelerator and speedo cables to protect them from the heat exchangers?
Replies(1 - 6)
JawjaPorsche
post Dec 30 2012, 01:37 PM
The accelerator cable is nowhere near the heat exchangers on my car. My clutch and speedo cables are far enough from the exchangers to not be a problem.
Maybe someone else on this forum thinks a heat shield is needed?
post Dec 30 2012, 01:44 PM
Sorry, should have been more specific, on the 914-6 the 3 cables all run along the same path under HE toward the transmission. The factory didn't put anything on them and clipped them to the HE but thought I saw a wrapped that someone has used.
jimkelly
post Dec 30 2012, 01:46 PM
Delaware USA
maybe a cloth exxhaust wrap is all the is needed?
http://www.jegs.com/c/Heat-Shields-Insulat...CFYqZ4Aod_lUAVQ
or this sleeve
http://www.jegs.com/p/JEGS-Performance-Pro...130487/10002/-1
Woody
post Dec 30 2012, 01:47 PM
Sandbox Rabblerouser and head toilet scrubber
http://tangerineracing.com/transmission.ht...lating%20Sleeve
mrbubblehead
post Dec 30 2012, 02:08 PM
Twodollardoug
this is what i use. i use it on the clutch cable, driver side parking brake cable (which sits on the exhaust) and my fuel lines... http://www.summitracing.com/search?keyword...leave&dds=1
gothspeed
post Dec 30 2012, 02:31 PM
Good stuff listed above (IMG:style_emoticons/default/smile.gif)
Here is another from McMaster Carr:
http://www.mcmaster.com/#standard-wire-ins...leeving/=ktklsf
- Lo-Fi Version Time is now: 4th January 2025 - 08:49 PM
