dfelz |
beach bum ![]() ![]() Group: Members Posts: 419 Joined: 7-June 12 From: San Diego Member No.: 14,538 Region Association: Southern California ![]() ![]() |
If you spin the rear wheel (car jacked up of course) and the wheel on the other side spins the opposite direction, is that just how all of them work, or is that only if there is a limited slip in there???
rktmn247 |
Irish Green with GT envy! ![]() ![]() Group: Members Posts: 347 Joined: 18-August 05 From: Mililani, HI Member No.: 4,612 Region Association: None ![]() ![]() |
That is an open diff, on a lsd both wheels will spin in the same direction.
914340 |
Newbie ![]() Group: Members Posts: 22 Joined: 15-August 10 From: Michigan Member No.: 12,057 Region Association: None ![]() |
If you spin the rear wheel (car jacked up of course) and the wheel on the other side spins the opposite direction, is that just how all of them work, or is that only if there is a limited slip in there??? That is a common 'open' style differential. An LSD or 'Posi' style would have both wheels turn in the SAME directions be it forward or reverse when rotated by hand with the car on jacks. |
messix |
AKA "CLUTCH KILLER"! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest ![]() |
If you spin the rear wheel (car jacked up of course) and the wheel on the other side spins the opposite direction, is that just how all of them work, or is that only if there is a limited slip in there??? That is a common 'open' style differential. An LSD or 'Posi' style would have both wheels turn in the SAME directions be it forward or reverse when rotated by hand with the car on jacks. given that the tranny would be in neutral, a limited slip would turn in the oposite if the tranny is in gear but with some resistance depending of the type of limited slip [loose term for this thread] the common friction clutch type will give a good amount of resistance. |
Lo-Fi Version | Time is now: 25th June 2024 - 10:30 PM |
