vitaminC |
searching... ![]() Group: Members Posts: 48 Joined: 29-August 10 From: NorCal Member No.: 12,121 Region Association: Northern California ![]() |
Okay. Today I drove a '73 2.0 with original FI. It started fine when cold, and the idle was smooth. Once underway, however, it was bucking like crazy! I've had a look at this trouble-shooting page, and it seems like there are a couple of possibilities- AAR, CTHS. After about 10 min it smoothed out and was much more drivable. Any thoughts?
The car has aftermarket headers and exhaust, so no heat exchangers. Not sure if this is related or not, but he said he had tested the compression fairly recently, and they were all between 120-140 (don't recall the exact numbers). Is this in an normal range? Pics More trim is installed vs what is shown in the pics. It was originally brown. Didn't seem to be any current rust issues, though the battery tray had clearly rusted in the past. Also, the rear trunk floor was repaired with fiberglass. |
jdlmodelt |
James D. Lane ![]() ![]() Group: Members Posts: 345 Joined: 30-November 12 From: Colorado Member No.: 15,210 Region Association: Southwest Region ![]() |
Okay. Today I drove a '73 2.0 with original FI. It started fine when cold, and the idle was smooth. Once underway, however, it was bucking like crazy! I've had a look at this trouble-shooting page, and it seems like there are a couple of possibilities- AAR, CTHS. After about 10 min it smoothed out and was much more drivable. Any thoughts? The car has aftermarket headers and exhaust, so no heat exchangers. Not sure if this is related or not, but he said he had tested the compression fairly recently, and they were all between 120-140 (don't recall the exact numbers). Is this in an normal range? Pics More trim is installed vs what is shown in the pics. It was originally brown. Didn't seem to be any current rust issues, though the battery tray had clearly rusted in the past. Also, the rear trunk floor was repaired with fiberglass. Mine smooths out after about 5 minutes |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
Aar is likely. Fiberglass repair in trunk is a big red flag.
Lo-Fi Version | Time is now: 20th June 2024 - 11:23 PM |
