CG-914 |
Member ![]() ![]() Group: Members Posts: 326 Joined: 27-December 10 From: LA/OC CA Member No.: 12,526 Region Association: Southern California ![]() |
Had my engine for machine work at Rimco,
and after they forget to send parts back I know finally after ... (IMG:style_emoticons/default/dry.gif) I have my dowel pins from the flywheel back I send in case they needed them for the balancing. I am not sure if they send me the right pins back so here are the pics with measurements... ![]() ![]() ![]() |
CG-914 |
Does somebody have a set laying arround he or she can compare the size?
20 mm x 6 mm (IMG:style_emoticons/default/icon_bump.gif) |
worn |
can't remember ![]() ![]() ![]() ![]() Group: Members Posts: 3,181 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest ![]() ![]() |
Does somebody have a set laying arround he or she can compare the size? 20 mm x 6 mm (IMG:style_emoticons/default/icon_bump.gif) Yeah, I have three out, waiting to go back in. I will try to remember tonight. Right off the bat though, the ones you have look spot on. |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
They are 6 mm O.D.
They stick out of the flywheel approximately 11 mm on the one I measured. Sorry, not pulling them out to get an overall length. |
pilothyer |
Member ![]() ![]() ![]() Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States ![]() |
Just saw this.....Looks like they sent you the correct ones..........Jerry
Lo-Fi Version | Time is now: 20th June 2024 - 06:09 AM |
