916 Rear bumper issue also rear spoiler?, 916 bumpers |
Dasnowman |
Jan 22 2013, 10:05 PM
You miss 100% of shots you don't take! Group: Members Posts: 265 Joined: 24-May 12 From: Tricities, B.C./ Lake Whatcom Member No.: 14,477 Region Association: Canada |
Hi guys I picked up some used 916 bumpers of a fellow teener and the front bumper seems to fit great. But the rear bumper really doesn't line up or fit well at all, anyone have any ideas? Where is the top lip of the bumper supposed to line up on the rear of the car and also the side indents don't seem to match well.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i156.photobucket.com-14477-1358913944.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i156.photobucket.com-14477-1358913945.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i156.photobucket.com-14477-1358913945.3.jpg) |
JamesM |
Jan 22 2013, 10:16 PM
Senior Member Group: Members Posts: 1,958 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
did you install these with the dog bones? looks like they are spaced out quite a bit. On mine they are bolted on directly with no spacers.
scotty b |
Jan 22 2013, 10:17 PM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
Do yourself a favor. Throw it away and buy a new one. You'll be WAAAAAAY ahead of the game. There were a couple manufacturers for those and you seem to have gotten one of the worst ones, plus it looks like it is full of bondo.
Dr Evil |
Jan 22 2013, 10:25 PM
Send me your transmission! Group: Members Posts: 23,030 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Scotty has HOURS into making my set fit my car perfectly. Hear his pain! (IMG:style_emoticons/default/wink.gif)
Dasnowman |
Jan 23 2013, 02:20 AM
Anyone have a close up of what the finish bumper should look like. I can get the bumper to come in closer as the bottom is hitting the exhaust but body lines seem weird on the sides.
Also the rear spoiler has no bolts or mounting holes ?? Looks like it was installed before... |
GeorgeRud |
Jan 23 2013, 07:43 AM
Welcome to the world of aftermarket fiberglass! Fitting these pieces makes the original price seem expensive when you figure out the time involved.
If labor is cheap (ie your time), enjoy your project. Otherwise, look elsewhere. |
Phoenix-MN |
Jan 23 2013, 08:03 AM
Senior Member Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 |
It took nearly 40 hrs to fit and shape my 916 front and rear bumpers. The front was the worst
monkeyboy |
Jan 23 2013, 09:38 AM
Senior Member Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None |
That's fiberglass. My neighbor who does show car work for a living has told me that good fiberglass parts are shit and it goes downhill from there.
ww914 |
Jan 23 2013, 09:53 AM
914 Convert Group: Members Posts: 435 Joined: 29-September 11 From: Central Coast, CA Member No.: 13,621 Region Association: Central California |
My front fit fine as did the rear with little reshaping. I did make brackets out of aluminum because they fit on an angle. The so-called "dog bones" would not have worked on my 75. I did have to re-shape the exhaust holes to make the Triad pipes fit better. I have spent hours on this work. I have removed all of the orange paint to find a lot of bondo. Some I fixed with resin and fiberglass. Today I am spraying the primer coat to see what it really looks like. I plan to paint them the same color as the car later today or tomorrow.
By the way, if I had it to do over, I would have bought brand new ones. I would have saved many hours of preparation. I would have done this even though mine fit pretty nicely. Well, if I go wide, I will have to do it anyway. |
Dasnowman |
Jan 23 2013, 01:38 PM
My front fit fine as did the rear with little reshaping. I did make brackets out of aluminum because they fit on an angle. The so-called "dog bones" would not have worked on my 75. I did have to re-shape the exhaust holes to make the Triad pipes fit better. I have spent hours on this work. I have removed all of the orange paint to find a lot of bondo. Some I fixed with resin and fiberglass. Today I am spraying the primer coat to see what it really looks like. I plan to paint them the same color as the car later today or tomorrow. By the way, if I had it to do over, I would have bought brand new ones. I would have saved many hours of preparation. I would have done this even though mine fit pretty nicely. Well, if I go wide, I will have to do it anyway. Looking good thanks for the post it really helped a lot. I like the orange blue 76 combo love to see it when it's matching it going to look good. Yes my front fits like that but ya the rear looks like it needs a ton of work, I'm on a budget so I might try to make it work. |
Tom |
Jan 23 2013, 02:53 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Warren.
I remember seeing pictures of the rear bumper on the car they came off of and the Triad outlets were centered fairly well. Work was supposedly done by a reputable body shop. I never test fit them to my car, but the Triad on my car is 42.5" driver's side inside outlet pipe to pass inside outlet pipe. Wonder if the dimensions changed a little over the years? I think even new ones are going to take some fitment. My guess would be the front fit so well because it had been fitted, modified, and installed previously. All of these cars seems to differ slightly in dimensions. I think the Phoenix Red looks good against the Blue! Tom |
ww914 |
Jan 23 2013, 05:30 PM
Warren. I remember seeing pictures of the rear bumper on the car they came off of and the Triad outlets were centered fairly well. Work was supposedly done by a reputable body shop. I never test fit them to my car, but the Triad on my car is 42.5" driver's side inside outlet pipe to pass inside outlet pipe. Wonder if the dimensions changed a little over the years? I think even new ones are going to take some fitment. My guess would be the front fit so well because it had been fitted, modified, and installed previously. All of these cars seems to differ slightly in dimensions. I think the Phoenix Red looks good against the Blue! Tom Hi Tom Actually the holes for the Triad are untouched in the photo I posted. I have since closed up the opening a little. Probably would have been fine, but I am kind of anal. I got them sprayed today with primer. Hopefully Laguna Blue tomorrow if it doesn't rain. I am trying to get them done and installed on the car for a run on Sunday. Again, if it doesn't rain. |
Jon H. |
Jan 23 2013, 08:25 PM
Member Group: Members Posts: 237 Joined: 1-July 11 From: Ottawa, Canada Member No.: 13,264 Region Association: Canada |
Not sure what look your going for but mine were blended into the body. With the looks of the bumper you have that might have been what was done to it before.
Attached thumbnail(s) |
David_S |
Jan 23 2014, 09:46 PM
Member Group: Members Posts: 430 Joined: 11-May 03 From: Dimmitt, Tx Member No.: 680 Region Association: Southwest Region |
I also blended mine to the body for that seamless look. I dont know that I have any good pics of the rear yet, but my avatar is of my front !!
Lo-Fi Version | Time is now: 21st September 2024 - 06:54 PM |
