Adjusted valves on a 914 today. Just met this guy, Managed to miss one thing |
JRust |
Jan 26 2013, 06:22 PM
914 Guru Group: Members Posts: 6,309 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Car sat for 3 hours to cool before starting.
Find TDC for cylinder #1 (distributor where it should be & mark in the right spot in the fan housing). Adjusted both intake & Exhaust to .15mm. Done Move onto Cylinder #2. Rotate the drivers rear wheel counter clockwise. Find the notch in the bottom of the flywheel. Through the little hole on the bottom of the bell housing. Adjust both intake & exhaust again to 0.15m. Done Move onto Cylinder 3. Rotate the rear wheel until I find the mark on the flywheel. verify I have it at TDC again at the distributor. Adjust both the intake & Exhaust again to 0.15. Done Move onto Cylinder #4. Adjust both the intake & Exhaust again to 0.15. Done (not (IMG:style_emoticons/default/headbang.gif) ) I put my valve covers back on. Get the car back on the ground & fire it up. Runs rough. I shut it off & think (IMG:style_emoticons/default/WTF.gif) did I forget. So I go back through the whole valve adjustment in my head. I think I have this down the farther I got along. Cylinders 3 & 4 went much quicker (IMG:style_emoticons/default/screwy.gif) . Son of (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) . Forgot to rotate the wheel & get TDC for #4 (IMG:style_emoticons/default/wacko.gif) . Guess I feel a little better as it makes sense now. Just feel like an idiot for not catching it before I buttoned it all back up (IMG:style_emoticons/default/confused24.gif) |
jsayre914 |
Jan 26 2013, 08:37 PM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
If it makes you feel any better, I adjusted mine perfectly a few years ago, then went in and had a bite to eat. Came out and fired it up, it would not idle at all
(IMG:style_emoticons/default/WTF.gif) Crawled under and found both rocker covers still layin on top of the heat exchangers. (IMG:style_emoticons/default/first.gif) |
Black22 |
Jan 26 2013, 09:26 PM
Senior Member Group: Members Posts: 886 Joined: 1-November 07 From: Creswell, OR Member No.: 8,290 Region Association: Pacific Northwest |
Where did you get the .15 number? I thought everything was .006,.008 for our engines?
Oh and zero for chromoly pushrods. |
Cap'n Krusty |
Jan 26 2013, 09:40 PM
Where did you get the .15 number? I thought everything was .006,.008 for our engines? Oh and zero for chromoly pushrods. That's .15mm, not .15 thousandths. You'll notice he did it the hard way. Using my method, you'll NEVER make the mistake he made, and it's a LOT less work.. The Cap'n |
Kirmizi |
Jan 26 2013, 09:41 PM
Senior Member Group: Members Posts: 836 Joined: 12-February 06 From: Wyoming, US Member No.: 5,568 Region Association: None |
.15mm, not inch. I know, I had the same question til I re-read it. (IMG:style_emoticons/default/biggrin.gif)
Mike |
BKLA |
Jan 26 2013, 09:46 PM
Really old member Group: Members Posts: 1,253 Joined: 14-August 05 From: OR Member No.: 4,590 Region Association: Pacific Northwest |
Where did you get the .15 number? I thought everything was .006,.008 for our engines? Oh and zero for chromoly pushrods. That's .15mm, not .15 thousandths. You'll notice he did it the hard way. Using my method, you'll NEVER make the mistake he made, and it's a LOT less work.. The Cap'n What's your method? |
walterolin |
Jan 26 2013, 10:23 PM
Senior Member Group: Members Posts: 685 Joined: 30-November 11 From: Louisville, Ky Member No.: 13,838 Region Association: South East States |
Black22 |
Where did you get the .15 number? I thought everything was .006,.008 for our engines? Oh and zero for chromoly pushrods. That's .15mm, not .15 thousandths. You'll notice he did it the hard way. Using my method, you'll NEVER make the mistake he made, and it's a LOT less work.. The Cap'n What's your method? Oh! missed that Cap'n! It's in the Lapuwali Classic threads under Cap'n's Valve Adjustment Procedure. Here: http://www.914world.com/bbs2/index.php?showtopic=28758 |
JRust |
Jan 27 2013, 12:05 AM
Read the pelican tech article. Question Cap'n ? You said .006 intake & .008 exhaust for a 1.8 & a 2.0. The pelican article says the 1.7 & 1.8 are both .006? Since ill be going back in. I want to make sure I get it right. So good sir what is the right number?
Your method definitely will be easier & makes sense |
aharder |
Jan 27 2013, 12:37 PM
Advanced Member Group: Members Posts: 4,429 Joined: 6-September 11 From: Dallas Texas Member No.: 13,524 Region Association: Southwest Region |
[/quote]
That's .15mm, not .15 thousandths. You'll notice he did it the hard way. Using my method, you'll NEVER make the mistake he made, and it's a LOT less work.. The Cap'n [/quote] (IMG:style_emoticons/default/agree.gif) I use it because it works the best for me and the process is easy (IMG:style_emoticons/default/biggrin.gif) |
Spoke |
Jan 27 2013, 12:52 PM
Jerry Group: Members Posts: 6,994 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Using my method, you'll NEVER make the mistake he made, and it's a LOT less work.. The Cap'n (IMG:style_emoticons/default/agree.gif) Did it once the hard way, then used the Cap'n way after that. |
Dave_Darling |
Jan 27 2013, 07:11 PM
914 Idiot Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Read the pelican tech article. Question Cap'n ? You said .006 intake & .008 exhaust for a 1.8 & a 2.0. The pelican article says the 1.7 & 1.8 are both .006? Since ill be going back in. I want to make sure I get it right. So good sir what is the right number? Only the sodium-filled exhaust valve on the 2.0 uses the 0.008" spec. All 1.7 and 1.8 valves, and the 2.0 intake, are set to 0.006". There is one reference (I forget which one) that lists the 0.008" spec for 1.8 exhaust valves, but it is wrong. --DD |
Cap'n Krusty |
Jan 27 2013, 08:28 PM
Back in the day, sodium filled exhaust valves were widely available for 1.8s and flew off the shelves at rebuild time. Everyone I knew in the 914 biz used them until they went NLA. I often err on the side of caution unless I know they're not sodium. I'll go back and change that in the post.
The Cap'n |
Cap'n Krusty |
Jan 27 2013, 08:38 PM
OK, it's fixed. No more whining.
The Cap'n |
Lo-Fi Version | Time is now: 26th June 2024 - 06:18 AM |
