Stock tire diameter? |
Elliot Cannon |
Feb 14 2013, 08:41 PM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
I re-measured my old wheels and tires. I thought they were 25 inches in diameter. Turns out they are actually 26.5 inches. Does anyone know what the diameter of a stock, mounted and inflated tire is? With my old tires, my speedometer was spot on at 70 mph and I'd like to keep it as close to that as I can when I buy new tires.
walterolin |
Feb 14 2013, 09:07 PM
Senior Member Group: Members Posts: 685 Joined: 30-November 11 From: Louisville, Ky Member No.: 13,838 Region Association: South East States |
Steel wheels, 1970, Michelin 165SR15 measured 25 inches, one on the car, spare on the ground same.
Krieger |
Feb 14 2013, 09:22 PM
Advanced Member Group: Members Posts: 4,733 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Dang pilots! Next thing you know you will be putting a timer on the dash and making "standard" rate turns when its foggy. I have an older Panorama article out and it list the "Theoreticle Unloaded Diameter" of a the original 165R 15 tire as 25.7" Yes I am splitting hairs too. 205/55/16 vs 205/50/16...
Krieger |
Feb 14 2013, 09:32 PM
Love the new cell. March '95
Attached thumbnail(s) |
Spoke |
Feb 14 2013, 10:37 PM
Jerry Group: Members Posts: 6,994 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
You can calculate the diameter with this formula:
Dia = [Rim size in inches] + 2 x [(Width in mm)/25.4] x [profile]/100 Ex: 165/80/15 Dia = 15 + 2 x 165/25.4 x 80/100 = 25.4 inches Or go to this site: Tire Size Calculator |
falconfp2001 |
Feb 15 2013, 12:08 AM
Pancho Pantera Group: Members Posts: 451 Joined: 5-December 10 From: Downey, CA Member No.: 12,456 Region Association: Southwest Region |
This is the tire calculator that I prefer.
http://www.miata.net/garage/tirecalc.html I found that a 205/65 15 will barely fit width wise but is almost perfect for diameter. Kept my cruising speed the same and looks nice under the fenders. I have pedrini's and the fit is perfect but tight. |
76-914 |
Feb 15 2013, 06:50 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,519 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
(IMG:style_emoticons/default/poke.gif) or this and look where I found it http://www.914world.com/specs/tirecalc.php
Lo-Fi Version | Time is now: 26th June 2024 - 03:18 AM |
