how do I save this? I removed it and hit it with acetone, my buddy the body shop dude painted this over |
rgolia |
Mar 4 2013, 03:03 PM
GeoJoe Group: Members Posts: 716 Joined: 5-February 10 From: PA Member No.: 11,329 Region Association: North East States |
Any suggestions on how to save it or am I just screwed (IMG:style_emoticons/default/sheeplove.gif) ? Well it looks like crap but better than painted over.
SirAndy |
Mar 4 2013, 03:07 PM
Resident German Group: Admin Posts: 41,945 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Any suggestions on how to save it or am I just screwed (IMG:style_emoticons/default/sheeplove.gif) ? Anything that isn't sharp or metal. Try a dull plastic knife or some such ... (IMG:style_emoticons/default/popcorn[1].gif) |
r_towle |
Mar 4 2013, 03:16 PM
Custom Member Group: Members Posts: 24,661 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
possibly tape and paint remover.
It might work to soften the paint if you do it quick...dont leave it on too long. then, use a plastic scraper like Andy said. rich |
Kaduku |
Mar 4 2013, 03:17 PM
Member Group: Members Posts: 344 Joined: 1-January 13 From: SF Bay Area Member No.: 15,324 Region Association: None |
Dude that suck! That's why I rather pay a stranger a lot of bucks for a proper job. Anyway, sorry this happened o you, but I do understand trying to save some money. Hopefully you can remove it.
mrbubblehead |
Mar 4 2013, 03:31 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
try goof off or graffiti remover. i have seen threads on the samba where guys remove the second paint jobs on vws. they will do the whole car to get down to the original paint. (IMG:style_emoticons/default/pray.gif)
balljoint |
Mar 4 2013, 03:32 PM
914 Wizard Group: Members Posts: 10,000 Joined: 6-April 04 Member No.: 1,897 Region Association: None |
Finger nails.
MrKona |
Mar 4 2013, 04:16 PM
Senior Member Group: Members Posts: 597 Joined: 25-July 05 From: Santa Rosa, CA Member No.: 4,469 Region Association: None |
possibly tape and paint remover. It might work to soften the paint if you do it quick...dont leave it on too long. then, use a plastic scraper like Andy said. rich (IMG:style_emoticons/default/agree.gif) I've removed paint from old power tools that have been repainted by previous owners. I used a mild "Citristrip" paint remover and found that the new paint is a lot softer then the old paint and comes off much easier. It'll start to peel quickly while the original paint remains intact. |
Bartlett 914 |
Mar 4 2013, 04:45 PM
Advanced Member Group: Members Posts: 2,218 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
I might be tempted to grind off the rivets and remove the plate. Clean the area and have him touch the spot where it was. There must be and easy way to clean it once removed. The sooner the better
John1180 |
Mar 4 2013, 04:51 PM
Newbie Group: Members Posts: 36 Joined: 27-February 13 From: Seattle Member No.: 15,590 Region Association: None |
Don't use paint remover or solvents! The first thing that will come off is the black, and you'll be left with a bare aluminum plate with some numbers stamped on it!
Tom_T |
Mar 4 2013, 05:32 PM
TMI.... Group: Members Posts: 8,320 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
I used Acetone on Q-tips & carefully eased & worked it off gently, to get off 4 over sprays. It works but takes time & patience, and you may need to touch up some of the black painted areas with matte black paint it you go too far.
I wouldn't use masking tape without first scoring the edge of the plate, since the acetone could wick up under the tape & onto the paint you don't want to remove. Go slow & gently & acetone will work. Also leave a few minutes for the paint to bubble up after your first wetting. Keep the Q-tips relative dryish with acetone, as you do not want any running! |
Kaduku |
Mar 4 2013, 05:37 PM
Finger nails. Great idea, but at the end, you may not have any nails anymore (IMG:style_emoticons/default/lol-2.gif) Jokes aside. No matter what method you decide on, you must do it ASAP. |
914outlaw |
Mar 4 2013, 05:51 PM
Dave Group: Members Posts: 201 Joined: 2-June 10 From: Central, NJ Member No.: 11,800 Region Association: North East States |
I would try plastic razor blades like these
http://www.amazon.com/Plastic-Razor-Blades...k/dp/B0020WVBG8 Good luck |
Cevan |
Mar 4 2013, 06:05 PM
Senior Member Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
No offense, but who the hell would paint right over that? (IMG:style_emoticons/default/WTF.gif)
bandjoey |
Mar 4 2013, 06:09 PM
bandjoey Group: Members Posts: 4,930 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Tape it off and wd40 and a soft brass dremm tool. Go slow and easy. Cut around it with a razor knife before starting
rgolia |
Mar 7 2013, 07:15 AM
This was one of his more minor abortions that I had to deal with. He lost my front turn signal buckets, wiper arms, wiper arm hardware, side marker lights, hood crest, and installed the fog lights upside down, etc. He ended up hurting his back and in the hospital for a month...had to close his shop. I had to deal with his uncle..whos IQ is printed on the side of a shoe box. I was actually just happy I got the car back. |
Kaduku |
Mar 7 2013, 07:33 AM
This was one of his more minor abortions that I had to deal with. He lost my front turn signal buckets, wiper arms, wiper arm hardware, side marker lights, hood crest, and installed the fog lights upside down, etc. He ended up hurting his back and in the hospital for a month...had to close his shop. I had to deal with his uncle..whos IQ is printed on the side of a shoe box. I was actually just happy I got the car back. Again, that's why I don't hire friends (IMG:style_emoticons/default/dry.gif) |
ejm |
Mar 7 2013, 07:53 AM
I can see the light at the end of the tunnel Group: Members Posts: 2,705 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
Those are not rivets holding the plate on, they are push pins with spiral grooves. Remove the speaker grill and they can be tapped out from the backside.
Chris H. |
Mar 7 2013, 08:28 AM
Senior Member Group: Members Posts: 4,049 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
I might be tempted to grind off the rivets and remove the plate. Clean the area and have him touch the spot where it was. There must be and easy way to clean it once removed. The sooner the better (IMG:style_emoticons/default/agree.gif) It won't look right unless the tag is ON TOP of the paint. You can touch up the area yourself since the paint is fresh. Also be careful what you scrape it with, that tag is somewhat fragile. |
Bartlett 914 |
Mar 7 2013, 10:25 AM
Those are not rivets holding the plate on, they are push pins with spiral grooves. Remove the speaker grill and they can be tapped out from the backside. (IMG:style_emoticons/default/agree.gif) I didn't realize you could get to them behind. That would make it easy to save them. They are a metric size. You can get similar push rivets here but the size is a little different an may require opening the holes |
914GT |
Mar 7 2013, 10:32 AM
Senior Member Group: Members Posts: 1,101 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region |
Definitely would want to score around the plate all the way down through the primer, otherwise it's going to pull all the new paint and probably the old paint off the door jamb when the plate is taken off.
Lo-Fi Version | Time is now: 27th December 2024 - 01:14 AM |
