Rear Calipers, Replacing old with PMB - What else to Get E-brake to work? |
Mblizzard |
Mar 9 2013, 02:33 PM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
Received CFO approval to order PMB rear calipers on the 17th! Everything about them seems top notch. Anyone else used them? If so what was your impression?
Currently the emergency brake does not work. The handle is operational and the cables seem to move the levers on the calipers. Tried adjusting the pads but the adjusters seem to not move the pads at all. So I am convinced that the problem is in the caliper. Of course, every time I am convinced I am right (IMG:style_emoticons/default/WTF.gif) So I thought I would ask if there was something else I was missing or should anticipate replacing with the calipers. |
type47 |
Mar 9 2013, 02:38 PM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
Make sure you have or can get the little pin and "C" clip that connects the end of the brake cable to the lever. I found a C clip at local hardware; 5/16" if I recall. Brake bleeder valves, rubber caps, pads with pins and springs ...
Spoke |
Mar 9 2013, 02:47 PM
Jerry Group: Members Posts: 6,994 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
This is common with restored rear calipers. I had the same issue with mine. Nothing wrong with the mechanism, it just needs to be loosened up.
Check out my thread for answers. Restored Rear Caliper E-Brake Break-in BTW, PMB is the tops. Eric is awesome to work with and helped me through several non-PMB related hub/brake issues. |
Eric_Shea |
Mar 9 2013, 03:02 PM
PMB Performance Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
He's talking about his old calipers...
Mblizzard |
Mar 9 2013, 03:55 PM
Eric - Because that process was for new/rebuilt calipers I take it I am better off not trying it on my old ones? I am not sure that even if it worked that I would feel comfortable continuing with the old ones.
Eric_Shea |
Mar 9 2013, 06:29 PM
The same basic thing "can" be happening but, with old calipers it's probably a rusty fluid build up around the sealing ring.
Here's what I recommend for anyone trying to get their old stuck rear calipers working again. 1. Put new fluid in the system. New fluids will help clean. 2. Move the handbrake arm back and forth. That will get the inner pistons moving freely in the bore so you can (hopefully) adjust it. 3. Remove the small c-clip on the outer adjuster and remove the 13mm slim nut. Tap that adjuster in and then push the piston back. 4. Put the nut back on and re-install the c-clip. Now try to adjust the caliper as you normally would. Adjust both pistons (inner and outer) and move them in and out as far as you can. The idea is to get the pistons moving back and forth in the bores with clean fluid. This will help scrub some grunge off the piston walls. 5. Change the fluid again or flush a little more through until it runs clear. No guarantees with this method, a lot of these smaller adjuster seals are old and hard and will start to leak. If this doesn't get them working again, or, if you have some fluid leaks, it really is time for a rebuild. Hope that helps. |
Mblizzard |
Mar 9 2013, 06:49 PM
Eric did precisely that and still have no movement. So I will be placing an order on the 17th!
Elliot Cannon |
Mar 9 2013, 08:02 PM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
I got calipers from Eric. Aluminum rear and "S" front. I like them so far but haven't installed them yet. The only problem is, he won't let me paint them red. Is that even fair? Can he do that? (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/happy11.gif)
Eric_Shea |
Mar 9 2013, 08:24 PM
Read the fine print in the contract Elliot
Spoke |
Mar 9 2013, 10:45 PM
I got calipers from Eric....The only problem is, he won't let me paint them red. Yeah, I didn't even ask. They looked too pretty to paint. Attached image(s) |
Mblizzard |
Mar 14 2013, 02:44 PM
Order placed! Can't wait to get them. Don't worry, No chance of me painting them Eric.
Mblizzard |
Mar 19 2013, 07:02 PM
Got the new rear calipers from Eric at PMB. WOW! Maybe not works of art, yet. But these things are truly magnificent. Eric even went the extra step to install the pads I ordered. PMB knows how to do it right. When it comes to brakes it has to be right and Eric will make sure it is right.
Attached image(s) |
SKL1 |
Mar 19 2013, 09:12 PM
Senior Member Group: Members Posts: 1,612 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
+100
My "new" calipers from PMB are sitting on the workbench waiting for me to finish the suspension rebuilding (see thread about removing old trailing arm bushings (IMG:style_emoticons/default/smile.gif) ) and they look better than new!! Can't wait to hook everything up- the cables are all clean and ready... Someday... |
Mblizzard |
Mar 20 2013, 03:11 AM
It is amazing the love that we have for these cars. They are far from being the best at anything, yet we will sit there for days dreaming about getting the next part or installing the one we have.
I will be replacing the front control arm bushings myself soon. But that is one job I wish would just magically happen. |
matt5596 |
Mar 20 2013, 07:39 AM
Member Group: Members Posts: 102 Joined: 28-September 11 From: Norris, TN Member No.: 13,619 Region Association: South East States |
It is amazing the love that we have for these cars. They are far from being the best at anything, yet we will sit there for days dreaming about getting the next part or installing the one we have. I will be replacing the front control arm bushings myself soon. But that is one job I wish would just magically happen. (IMG:style_emoticons/default/agree.gif) I keep accumulating parts but not accumulating any time to install them. (IMG:style_emoticons/default/hissyfit.gif) |
Mblizzard |
Mar 30 2013, 06:03 PM
Well maybe it is not the most perfect presentation of Eric's work but I think the looks great. It is nice to get a part, install it, and it works exactly as it should.
Everything about the purchase from PMB says it was the best choice I could make. Attached image(s) |
Cairo94507 |
Mar 30 2013, 06:09 PM
Michael Group: Members Posts: 9,858 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
You will never regret your decision to go with PMB.
Lo-Fi Version | Time is now: 26th June 2024 - 10:06 AM |
