> Front hood release, Proper operation?
saigon71
post Mar 12 2013, 09:06 AM
Just installed my front hood. The release cable works well, but it does not retract on its own (you have to manually push it back). Is this how it is supposed to operate? I found a rogue spring in the front trunk a while ago and I am wondering if it came out of the latch mechanism.
Thanks,
Bob
Replies(1 - 7)
toolguy
post Mar 12 2013, 09:19 AM
There is suppose to be a little, but somewhat strong, spring inside the latch assembly. . It helps the handle and cable return but it's not uncommon to need to help it by pushing the handle back in.
JawjaPorsche
post Mar 12 2013, 09:20 AM
I have to push my handle back in every time. No problem.
mrbubblehead
post Mar 12 2013, 10:13 AM
Twodollardoug
mines the same way. i thought that was just the way it worked. (IMG:style_emoticons/default/popcorn[1].gif)
URY914
post Mar 12 2013, 10:20 AM
It should return on it own but not all do after 40 years.
post Mar 12 2013, 10:56 AM
914-6 GT in waiting
Make sure the cable and all the pivot points are lubed
Kaduku
post Mar 12 2013, 11:06 AM
QUOTE(JawjaPorsche @ Mar 12 2013, 07:20 AM) *
My last MGB did that too, and yes, I just push it back in. On my 914, it goes back in on it's own, but I still push it in just to be sure (IMG:style_emoticons/default/confused24.gif)
saigon71
post Mar 17 2013, 08:37 PM
Thanks for the info... (IMG:style_emoticons/default/beerchug.gif)
The spring I found in the trunk definately came from the latch to help it on the return motion. Re-installed it but didn't notice much difference in the operation:
- Lo-Fi Version Time is now: 27th December 2024 - 01:22 AM
