Steering U-Joints |
Steering U-Joints |
aylanco |
Nov 18 2004, 09:20 PM
Member Group: Members Posts: 106 Joined: 19-July 04 From: Ann Arbor, MI Member No.: 2,371 |
Hi All,
My new-to-me '73 2.0 is in need of the Turbo tie rods for sure, but I am a little suspect about the steering u-joints under the dash. They seem tight when I grab or wiggle them, but if I turn the wheel I can feel (and hear) them undulate. They just feel a bit sloppy when turning the wheel. I have seen almost nothing discussed about them, have not seen anything in books/manuals other than identifying them, and have not seen them offered in parts catalogs. I know the Rodders use them and they are available that way BUT....does anyone have any insight on the maintenance and or replacement of these? I know I should do the tie rods first but is this u-joint problem a common occurence? BTW, this 914 is too cool. I have hardly driven my other cars since I got this!!! (IMG:style_emoticons/default/mueba.gif) |
Jeff Bonanno |
Nov 18 2004, 09:25 PM
il dottore Group: Members Posts: 421 Joined: 30-April 03 From: San Diego, CA Member No.: 636 |
you sure it's the u-joints, Seb? they don't see much stress or weather. could be several other front end suspension components before these joints.
jbb |
aylanco |
Nov 18 2004, 09:30 PM
Hi Jeff,
I don't count anything out right now, Jeff!! Although I do highly suspect the u-joints. They make a slight rumbling noise and undulate when the wheel is turned back and forth, and the steering is a bit sloppy. I hope the tie rods solve it all, but who knows??!!?? (IMG:style_emoticons/default/wacko.gif) Any other thoughts out there? |
scotty914 |
Nov 18 2004, 09:37 PM
suby torque rules Group: Members Posts: 1,525 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 |
bushings in steering column go quite often ( after 30 years) also the steering rack
KenH |
Nov 18 2004, 09:39 PM
Senior Member Group: Members Posts: 680 Joined: 16-January 03 From: Gilroy, CA Member No.: 156 |
Jack the car up so the front wheels are not on the ground. Then see if the steering still feels bad.
Also the U-joints are not linear and the 2 must be alingned propelry or the steer wheel will feel like it is going "over center" - not rotating smoothly. Look under the dash you should not see any slopp in the joints as the steering wheel is moved back & forth. Just some thougths Ken |
aylanco |
Nov 18 2004, 09:43 PM
Hi Ken,
Thanks for the advice on that....I definately see slop when the wheel is turned back and forth. |
aylanco |
Nov 18 2004, 09:48 PM
As I said before, my first move will be turbo tie rods (as well as checking out the rest of the front end) but if the
u-joints don't check out OK then is there a proper procedure for replacement? Is there a good source for them or should I do the Rodder thing and get the nifty stainless units I see in the catalogs?!? BTW they are not cheap from those sources... |
Lo-Fi Version | Time is now: 23rd June 2024 - 02:05 PM |
