> any tips on cleaning transmision
wes
post Mar 22 2013, 12:35 PM
wes
I have pulled the transmission on my parts car removed lose oil and grime with Gunk spray let it sit then took it to the car wash tried cleaning it up with the engine cleaner at the car wash, started to scrape the (IMG:style_emoticons/default/screwy.gif) build up mess with plastic scraper and much of it just wont come off well its certainly much better but I want it nice and clean looking like my new engine any tips on cleaning years of baked on gunk?
Replies(1 - 19)
ThePaintedMan
post Mar 22 2013, 12:39 PM
Well, I was able to decipher what you were saying even though there wasn't a period anywhere in your post. (IMG:style_emoticons/default/blink.gif) Dr. Evil will kill me for saying this, but I used a couple cans of brake cleaner. A lot of guys don't believe in this because it strips away the original coating that was on the transmission to protect it. After I got mine clean I repainted it silver though, just in case. Good luck!
mrbubblehead
post Mar 22 2013, 01:02 PM
Twodollardoug
i use aircraft paint stripper.
steuspeed
post Mar 22 2013, 01:21 PM
If you get it clean and want to paint it, I recommend Aluma Blast from Eastwood. I'm doing my Alfa trans with it and it looks great.
http://www.eastwood.com/ew-aluma-blast-set.html
914Eric
post Mar 22 2013, 01:33 PM
I put a little heat to mine with a torch and it melted off like butter.
chads74
post Mar 22 2013, 02:33 PM
I put my kids to work srcapping at mine, after a couple days and a new coat of silver paint it looked pretty good.
Jeffs9146
post Mar 22 2013, 02:40 PM
Ski Bum
I use AWSOME from the $ store! It works great!
spray on and let it sit for 10-15 minutes, use a wire brush and a screw driver to loosen the tough stuff and spray more on. Let it sit for a few more minutes and hose it off! If you have a pressure washer even better!
Repeat until clean! 2 - 3 times should be enough!
Dr Evil
post Mar 22 2013, 03:11 PM
Send me your transmission!
Brake cleaner is fine. Water is not if it gets inside. I use the Awesome that Jeff speaks of since he posted about it a while ago. Ez-off was my old go to, but Awesome is too cheap and easy not to use.
Mblizzard
post Mar 22 2013, 03:18 PM
There are a lot of harsh cleaners that will do the job. But as many others have said, a little heat goes a long way. While I am not willing to use a torch on mine, warming the trans with an electric heater or heat gun will help a lot. Also any water based cleaner will work better when warm.
Just be careful about trying different cleaners one after another and creating a situation where you are mixing chemicals. So bad and dangerous things happen when chemicals are mixed. Fully rinse one cleaner before trying a new one.
gms
post Mar 22 2013, 03:27 PM
QUOTE(Dr Evil @ Mar 22 2013, 04:11 PM) *
are you guys referring to this?
http://www.awesome-cleaner.com/
Andyrew
post Mar 22 2013, 03:30 PM
Spooling.... Please wait
Pretty sure its this
http://www.dollartree.com/LA-s-Totally-Awe...97717/index.pro
Jeffs9146
post Mar 22 2013, 03:32 PM
Ski Bum
Yep thats the stuff! (IMG:style_emoticons/default/beerchug.gif)
LA's Totally Awesome
Madswede
post Mar 22 2013, 05:19 PM
Flat Out Driver
As for protection after cleaning, mine was coated with Cosmoline. www.cosmolinedirect.com ... Pretty sure it's close to what the 901 tranny came with from the factory. Richard Casto at Blue Sky Motorsports did mine. I'm sure he can talk to the specifics.
Dr Evil
post Mar 22 2013, 05:37 PM
The factory coating sucked! It does not last the life of the gear box, it is gone after a few years. I wont use it. There is better stuff out there that lasts much longer.
wes
post Mar 22 2013, 05:49 PM
wes
You guys are great thanks! I had no idea that the case was coated with anything other than engine oil and road dust!
Madswede
post Mar 22 2013, 06:07 PM
Flat Out Driver
Before I get corrected, Rich used something that was "Cosmoline like" I think. (IMG:style_emoticons/default/unsure.gif)
Anyway, what do you use then Evil?
gopack
post Mar 22 2013, 07:07 PM
CHEESEHEAD in CA, MARK
QUOTE(gms @ Mar 22 2013, 02:27 PM) *
I used that Awesome at the Disco Bay tranny clinic, Jeff gave me a spray bottle full!. sprayed it on, drove the shell to the car wash (guts removed) and pressure washed it, looked great! Jeff gave me a spray bottle full!
injunmort
post Mar 22 2013, 07:23 PM
I am by no means authority, but it is my understanding that the transmission case is magnesium. based on that assumption cleaning it with whatever not corrosive means is fine, but once that is done, it needs to be painted or otherwise coated. mag oxidises and becomes brittle in no time if not protected from the atmosphere. on my matchless g50 the cases and hubs were mag and had an aluminized gold paint that was on any of the magnesium parts. it used to turn green overnight without a barrier.
Jeffs9146
post Mar 22 2013, 07:44 PM
Ski Bum
QUOTE(injunmort @ Mar 22 2013, 06:23 PM) *
I would guess it is more of a east coast thing because of the salt on the roads!
I have not had any problems here in central california!
Dr Evil
post Mar 22 2013, 07:50 PM
There is at least one thread that covers this ad nauseum. Check them out (IMG:style_emoticons/default/smile.gif)
- Lo-Fi Version Time is now: 26th December 2024 - 07:03 PM
