Wiring question, Help identify wiring under dash |
442nd914s |
Apr 3 2013, 07:32 PM
Member Group: Members Posts: 139 Joined: 25-July 12 From: KC Suburb Member No.: 14,718 Region Association: None |
Found this loose wire underneath the dash. Travels under stearing colum and dissapears by the front trunk release. I havent checked for voltage but it looks like it would. 16-18 gauge wire with stock spade connectors Its on a '73
P.s. Its not the wire that goes to the speaker. That one is already accounted for Thanks in advance |
914Sixer |
Apr 3 2013, 07:41 PM
914 Guru Group: Members Posts: 8,920 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
NOT stock wiring.
Mike Bellis |
Apr 3 2013, 07:42 PM
It looks like a speaker wire. Does not look factory.
JeffBowlsby |
Apr 3 2013, 08:45 PM
914 Wiring Harnesses Group: Members Posts: 8,575 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Jmedeiros |
Apr 3 2013, 09:32 PM
Member Group: Members Posts: 99 Joined: 12-November 12 From: Los Banos, CA Member No.: 15,138 Region Association: Northern California |
I just found one in the new project that went to a light switch for the rear trunk. Is there a light that's not working when you open the front trunk??
914Sixer |
Apr 4 2013, 07:08 AM
NO front trunk light on 914's. Rear trunk light works only when lights are on and is part of the wiring harness.
Lo-Fi Version | Time is now: 25th June 2024 - 11:40 PM |
