VegasRacer |
ELVIRA ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,527 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None ![]() ![]() ![]() |
I've read all the old threads I can find on the subject. I've Googled until I went (IMG:style_emoticons/default/wacko.gif) .
I have visited most of the audio stores in a 10 mile radius. The more I look - the more confused I get. (IMG:style_emoticons/default/headbang.gif) It is getting close to time for making a decision and spending my $$'s. The casette deck and one blown speaker have got to go. (IMG:style_emoticons/default/ar15.gif) My budget is $500 max. Can I find something that will make me happy? Do I need a power amp and / or a sub woofer? I am favoring the Kenwood EZ500 head unit. It seems as good as most and better than many. I do like the retro look. I'm not crazy about the flip down front to play a CD. I don't need the remote. (IMG:http://www.infinitecaraudio.com/shop/uploads/im_ez500_lrg_2004_kusa.jpg) I'll probably go with the speaker pods that morphenspectra sells. Are these really the best way to go? Any recommendations for what I should use to fill them? I want something good. Polk Audio, Infinity, Boston Acoustics. Should I be looking at 2 way or 3 way speakers? I don't want separate tweeter components. Please help me spend my money. What do you have that you like? What should I avoid? Any input would be greatly appreciated. |
Tab914 |
Member ![]() ![]() Group: Members Posts: 158 Joined: 25-April 04 From: Alexandria, Ontario, Canada Member No.: 1,978 Region Association: Canada ![]() |
I guess the stereo is totally up to you. Go with your gutt and first idea. I have a set of those speakerpods that I bought from those guys. They are nice to do business with and the shipping was fast. They fit perfectly in the car and have a nice slick look. I really like them and recommend them. Hope that helps.
Cheers, Dominic. (IMG:style_emoticons/default/wink.gif) |
Chris914n6 |
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,352 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region ![]() |
I've had Kenwood stuff last forever. Value for features is good.
Morph' speaker pods are the easy/cheap way to go. The 6.5" speaker is about the best low end depth you're going to realistically get without a powered sub. Speakers all sound different to different people - so go listen to them with your favorite CD. I love the Infinity Kappa in my truck...since '96 (IMG:style_emoticons/default/biggrin.gif) 3-ways tend to be 'tinny'. Too much high range bias. We need to do lunch so I can see this new car of yours (IMG:style_emoticons/default/beerchug.gif) Chris |
Twystd1 |
You don't want to know... really..... ![]() ![]() ![]() ![]() Group: Members Posts: 2,514 Joined: 12-September 04 From: Newport Beach, California Member No.: 2,743 ![]() |
You should of seen my 72 teener when I bought it. There was two 10" Sub woofer cut outs in the engine firewall, firing a pair of 10s into the cab.
Could hear the engine throught the cones. The voice coils would overheat in 5 minutes and pruduce histericly obtuse bass imaging. Sounded like the drivers were making the sounds like a small rocket taking off... was really good for a laugh. Am still welding the holes up.. Stitch by stitch. Really the only way that I have made good sound in a Teener was to put two 5 inch SEAS Subs (yup they make em) in the center console with two molded speaker pods in the kick panels next to my feet. Had to make a custom fiberglass enclosure for em. The kicks had a 6" DynaAudio Mid base and a DynaAudio D-28 soft dome tweeters with hand made crossovers. Had an Orion 5 channel amp in the front with a changer. Ran the two subs in parralel to create a 2 ohm load for the sub channel of the amp. Ran everything else in the standard fashion. Head unit had DSP. In this way I could delay whatever speakers I needed to that would allow me to bring the sound stage up into the windshield. Took a crap load of tweaking to get the sound to come out of the windshield. Yet it came out pretty good. Actually sounded very tight, and loud when needed on the freeway or with the top off. The trick was to know that there REALLY is a 5 woofer that is tight and will go down to 35HZ without falling on it's face. The other trick is that I had to make a custom fiberglass enclosure for the 6" mids in the kick. It is imperative to NOT let the front sound wave from the speaker hit the back sound wave. Because they cancel each other out... Thats the downside of having OPEN BACK speaker pods. They are to some degree self cancelling. And the more you turn em up, the more they cancel. If you are good at crafting fibeglass and understand the basics of physcoaccoustics. Shit howdy.. you can do it. Just spend a month reading before you start the project. Make some parts (enclosures) out of card board. Tape them to wherever you think they can fit. Do your best to have the speakers pointed at your head if possible. And buy the absolute best components you can find. Buy em used and save some money. Speakers either work or they don't. Same goes for amps. Buying high end used components is a great way to go.....!!!!!! Just my .02 worth Twystd1 (IMG:style_emoticons/default/ar15.gif) (IMG:style_emoticons/default/ar15.gif) (IMG:style_emoticons/default/ar15.gif) |
markb |
914less :( ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California ![]() ![]() |
QUOTE(Chris914n6 @ Nov 22 2004, 10:08 PM) I've had Kenwood stuff last forever. (IMG:style_emoticons/default/agree.gif) I put a Kenwood in my 93 Nissan when I bought it new. The stereo still kicks butt. |
McMark |
Head units are all about looks and ease of use. If you need more power later, add an amp. Most all units output the same power. Buy something you like the look of and is easy to use. I like the one pictured. (IMG:style_emoticons/default/biggrin.gif)
Kerrys914 |
Dear, the parts I just sold paid for that part ;) ![]() ![]() ![]() Group: Members Posts: 1,568 Joined: 26-December 02 From: Williamsburg, VA Member No.: 16 ![]() |
Anything with XM Radio (IMG:style_emoticons/default/smilie_pokal.gif)
Joe Ricard |
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 ![]() |
You guys have stereos in your 914's?????
HMM Then I wouldn't have anyplace to put my gages. Not that I cold here a stereo anyway. I usually wear ear plugs when going for a drive over 20 minutes. Just ripped the stereo out of the project car. OMG what a bad job of installation. 3 speakers in the doors. At least the panels were not real. then there was an amp in the trunk and a 8" cheapy sub in a home made center console. |
skline |
Born to Drive ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,910 Joined: 26-December 02 From: Costa Mesa, CA Member No.: 17 Region Association: Southern California ![]() |
I have a Kenwood unit in my 03 truck, it works good and the price was cheap. Get one that plays MP3's as you dont have a lot of room to carry a lot of CD's without getting them screwed up. My 914 has a Sony unit installed, it has a remote control but you dont need to use it. It is handy though sometimes. The Sony unit is the one I like best, ease of use is a must for in a 914 as you dont want to have to look at the unit to change channels or tracks while you are driving. The speaker pods from Morph are the best way to go. Both Sony and Kenwood have the Sirrius radio hookups integrated in. Just thought I would add my .02 cents.
iamchappy |
It all happens so fast! ![]() ![]() ![]() ![]() Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest ![]() ![]() |
Before you weld up those 10" sub holes in your firewall you may want to look for some Revere Ware ss bowels like ive done. This is the second 914 ive mounted subs in the firewall with these enclosers.
Attached image(s) ![]() |
iamchappy |
another from inside
Attached thumbnail(s) ![]() |
BIGKAT_83 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States ![]() ![]() ![]() |
JmuRiz |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,446 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region ![]() ![]() |
The unit that was pictued above looks great. I really like the dual knobs, has an 'older' look to it. However for some reason Kenwood did not put a subwoofer pre-amp in it (IMG:style_emoticons/default/mad.gif) I have a bazooka tube right in front of the passenger seat and would love to have a unit that looks like that one w/ a dedicated sub pre-amp output. Maybe next years model will.
Then again I did a stereo system in mine but rarely turn it on, maybe 2 times in the past year, haha. I'd rather listen to the motor and try to pinpoint squeeks and rattles, haha. |
Flat VW |
Illegal Soapbox Derby Racecar ![]() ![]() ![]() Group: Members Posts: 1,692 Joined: 13-November 04 From: Phoenix, AZ Member No.: 3,105 ![]() |
I've used headphones in my previous 914. I really liked it, I installed micro phono jacks under the "third seat" in the plastic console and wired each up to the rear channels of the fader. I used to have two sets of "folding headphones" that fit nicely in the glove box. In addition I also upgraded the stock speakers to the best I could find that would fit in the stock enclosures. Ahha, the memories, my wife and I would take off the top, roll up the windows annd crank up the heat during Arizona winter nights, simply wonderful and wonderfully simple pleasure.
Headphones are hard to beat for sound quality, especially in a loud car. I intend to do the same thing in my current 914 (but maybe with the addition of an intercom) after all the gremlins are gone. I developed a new one just last night, after the car sat in the rain yesterday when one turns the steering wheel to just the right spot either right or left the horn toots. I am unsure whether while driving last night people thought I was just friendly or rude. (IMG:style_emoticons/default/cool_shades.gif) |
aircooledboy |
Sweet Pea's 1st ride in daddy's "vroom -vroom" ![]() ![]() ![]() Group: Members Posts: 1,672 Joined: 4-February 04 From: Rockford, IL Member No.: 1,629 Region Association: Upper MidWest ![]() |
(IMG:style_emoticons/default/ohmy.gif) DAMN!!!! (IMG:style_emoticons/default/ohmy.gif)
I can't believe you guys all forgot to tell him about the critical "insulating foam coated 110 volt breaker" required for any good stereo instulation. (IMG:style_emoticons/default/headbang.gif) And you guys call yourselves 914 fans. (IMG:style_emoticons/default/w00t.gif) (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/monkeydance.gif) Attached image(s) ![]() |
aircooledboy |
BTW, illegal in most, if not all states for the driver to have headphones on. Kinda dangerous.
Pnambic |
Honk if you like obscene gestures! ![]() ![]() ![]() Group: Members Posts: 914 Joined: 9-April 03 From: Atlanta, GA Member No.: 546 Region Association: South East States ![]() |
You might want to check on the legality of wearing headphones while driving. I seem to recall reading that its illegal in some states.
Then of course, look at the features that you value. For instance, I'd want a stereo that I could put a CD full of MP3's in and listen to. Maybe you're interested in XM/Sirius satellite radio. I have a Sony ES model head unit in my Saturn that has performed exceptionally since 1995. Gotta like that. |
Flat VW |
QUOTE(aircooledboy @ Nov 23 2004, 09:30 AM) (IMG:style_emoticons/default/ohmy.gif) DAMN!!!! (IMG:style_emoticons/default/ohmy.gif) I can't believe you guys all forgot to tell him about the critical "insulating foam coated 110 volt breaker" required for any good stereo instulation. (IMG:style_emoticons/default/headbang.gif) And you guys call yourselves 914 fans. (IMG:style_emoticons/default/w00t.gif) :lol: :monkeydance: Nope, that is a double pole circuit breaker, <220 VAC> (IMG:style_emoticons/default/welder.gif) |
Flat VW |
QUOTE(Pnambic @ Nov 23 2004, 09:34 AM) You might want to check on the legality of wearing headphones while driving. I seem to recall reading that its illegal in some states. Then of course, look at the features that you value. For instance, I'd want a stereo that I could put a CD full of MP3's in and listen to. Maybe you're interested in XM/Sirius satellite radio. I have a Sony ES model head unit in my Saturn that has performed exceptionally since 1995. Gotta like that. Legal, Schmiegal.... (IMG:style_emoticons/default/devil.gif) I did kinda slip em off when the fuzz was around though. (IMG:style_emoticons/default/wink.gif) On a practical note the type of headphones I had were not risky as far as hearing a fire truck, for example (not the totally over the ear type). Heh man this is the Wild West out here! (IMG:style_emoticons/default/aktion035.gif) Live a little!! (IMG:style_emoticons/default/tunez.gif) (IMG:style_emoticons/default/pirate.gif) |
aircooledboy |
QUOTE(Flat VW @ Nov 23 2004, 11:53 AM) Nope, that is a double pole circuit breaker, <220 VAC> (IMG:style_emoticons/default/welder.gif) Doh! (IMG:style_emoticons/default/spank.gif) How could I miss that. (IMG:style_emoticons/default/headbang.gif) There goes my union card. (IMG:style_emoticons/default/chairfall.gif) |
Lo-Fi Version | Time is now: 30th June 2024 - 03:45 AM |
