gunny |
Member ![]() ![]() Group: Members Posts: 205 Joined: 17-October 12 From: Madison Al Member No.: 15,051 Region Association: South East States ![]() |
I have a 1976 2.0 Djet with was purchased new in California. It came with the catilitic converter, air pump and speed limiter but have all been removed. Is there an issue with the wiring harness having nothing plugged into the speed limiter conection. Do I need to do anything?
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
no, just leave it unplugged unless you want one as I think I have one in my stash
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
The "speed limiter" is actually a rev limiter. They cut the fuel (like modern cars do) instead of the spark so that you don't get unburned fuel dumped into the exhaust, potentially killing the catalyst.
Leaving it unplugged simply means that there is no rev limiter on the fuel. You can still install one of the spring-loaded distributor rotors to cut the spark when you spin the motor fast enough if you like. --DD |
Lo-Fi Version | Time is now: 26th June 2024 - 07:58 AM |
