Replacing Weltmeister sway bar bushings |
Scott S |
May 15 2013, 11:43 AM
Small Member Group: Members Posts: 1,697 Joined: 30-April 03 From: Colorado Member No.: 633 |
Hi All -
I am getting ready to replace the bushings on my weltmeister sway bar. The bushings I am referring to are the ones that are actually on the bar itself - not the drop links. I did a bunch of searching but did come up with much. Has any one done this? Once I remove the three bolts in the wheel well, do the bushings simply slide on and off of the bar? They are a pretty hard material. Thanks! Scott S |
shuie |
May 15 2013, 12:41 PM
Member Group: Members Posts: 352 Joined: 17-May 04 From: baton rouge, la Member No.: 2,075 |
jmill |
May 15 2013, 09:26 PM
Green Hornet Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
I have a 22mm Welt bar and bought new bushings for it also. I haven't installed them yet. I will say that the larger bar will slide through one side and out the other with semi worn bushings. I highly doubt you need to split them with a large bar. If it's the smaller stock bar then you need to split them.
r_towle |
May 15 2013, 09:27 PM
Custom Member Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Custom bronze, after I crushed the first set.
lrm914 |
May 17 2013, 09:50 PM
Member Group: Members Posts: 50 Joined: 3-September 11 From: ga Member No.: 13,514 Region Association: South East States |
Hi All - I am getting ready to replace the bushings on my weltmeister sway bar. The bushings I am referring to are the ones that are actually on the bar itself - not the drop links. I did a bunch of searching but did come up with much. Has any one done this? Once I remove the three bolts in the wheel well, do the bushings simply slide on and off of the bar? They are a pretty hard material. Thanks! Scott S Hey Scott, Coincidentally I am doing the same replacement you are. Can you please tell me where you purchased the new bushings for your 22mm Weltmeister sway bar. I need to replace mine as well. Does Automotion carry them? Pelican? Do the stock bushing fit on the aftermarket sway bar? Thanks Larry |
Scott S |
May 20 2013, 11:03 AM
Hi Larry -
I got them from automotion (prepare yourself - unless you are ordering a bumper for a 1996 chevy pickup, their customer service folks are absolutely worthless...) Here is the part number for the 22mm: PZC-SB-1100D If anyone should need the 19mm, here is the part number: P9132343 They may tell you that the part numbers sound incorrect. That means they did not actually take the time look it up. Trust me, the numbers are correct. I bought a set of each size just last month just to have them on hand. If you dont mind - can you update me on how your install goes? I am still nervous about simply opening mine up (previous owner install - no idea how it goes togther....) Good luck! |
Lo-Fi Version | Time is now: 25th June 2024 - 06:32 PM |
