Brake Line Fitting Thread Size?, Can anyone confirm? |
74914LE |
May 22 2013, 08:14 PM
Member Group: Members Posts: 136 Joined: 6-April 04 From: Fort Worth, TX Member No.: 1,895 |
Can anyone confirm the Thread Size on the Brake Line Fitting that screws
into the Brake Calipers? I believe it is a M10x1.0, but want to confirm before I start the job of putting in a Heli-Coil into the Caliper. Thanks! |
Mike Bellis |
May 22 2013, 08:35 PM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
I think the size is correct but I don't think a helicoil will hold the pressure of the fluid. It is a glorified spring and not t true thread. You should call Eric at PMB first.
jcd914 |
May 22 2013, 08:49 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
stugray |
May 23 2013, 07:25 AM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
The thread is 10.0X1.0.
A helicoil should work fine as the seal is made by the end of the fitting, not the threads. However, I would still check with Eric as stated above. Stu |
Eric_Shea |
May 23 2013, 07:38 AM
PMB Performance Group: Admin Posts: 19,289 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
I'm going to hook Ford up with a new caliper back 1/2. Stu is correct, the seal is the seat and I've seen plenty of them done that way but... why bother? Eliminate all doubt with a simple fix; the right part.
Cap'n Krusty |
May 23 2013, 07:39 AM
In my professional opinion, unless you have the tools and ability to precisely recut the tapered seat at the bottom of those threads, the odds of the repair being successful AND safe, are close to nil. It's your BRAKES!
The Cap'n |
Mblizzard |
May 23 2013, 08:58 AM
I am the cheapest guy around if you ask my wife. But when it comes to brakes I will spend money. Granted brakes are not my strong point but with my 1971 I rebuilt the master cylinder and thought I did a great job. But on the first test drive a complete blow out of the seals sent me crashing into a ditch. Again brakes are not my thing but I learned my lesson. I am sure there are a number of possibilities for the failure but I have to think that my lack of experience was the biggest factor.
74914LE |
May 23 2013, 09:25 AM
Many thanks to all for your comments! I am proceeding with a new Caliper Half!! After many discussions and reading blogs about this topic, the potential risks do not justify the thrift or opportunity to test my skills on either getting it right, or on navigating the 914 in the event of a brake failure. (This happened once 30 years ago, and am not really up for that kind of adrinaline rush again!)
To follow Eric's comments, it can be done, and the seal is not with the treads, so a Heli-Coil could work just fine, BUT, 40 year old metal is a huge unknown. Not worth the risk!!! I like to think of this as a Known, Unknown!! The likelihood exists, and it should not be tried. Period!! If I had thought through this more, I probably would not have posted this to begin with, but if it keeps someone safe in the future, then I am OK with it. Appreciate everyone keeping me on the road! |
Cap'n Krusty |
May 23 2013, 09:39 AM
Many thanks to all for your comments! I am proceeding with a new Caliper Half!! After many discussions and reading blogs about this topic, the potential risks do not justify the thrift or opportunity to test my skills on either getting it right, or on navigating the 914 in the event of a brake failure. (This happened once 30 years ago, and am not really up for that kind of adrinaline rush again!) To follow Eric's comments, it can be done, and the seal is not with the treads, so a Heli-Coil could work just fine, BUT, 40 year old metal is a huge unknown. Not worth the risk!!! I like to think of this as a Known, Unknown!! The likelihood exists, and it should not be tried. Period!! If I had thought through this more, I probably would not have posted this to begin with, but if it keeps someone safe in the future, then I am OK with it. Appreciate everyone keeping me on the road! Posting good questions here is the right thing to do. Posting stupid questions here is also OK. Ignoring the answers of people who know what they're talking about and shopping the question around until you get the answer you want is behavior that is stupid and cannot be excused. The Cap'n |
Lo-Fi Version | Time is now: 26th December 2024 - 09:26 AM |
