Transmission Leak, Side Shift |
Nor.Cal.914 |
May 26 2013, 04:39 PM
1975 914 3.0SC Group: Members Posts: 1,050 Joined: 28-January 05 From: Weatherford, TX Member No.: 3,523 Region Association: None |
I just started driving my 914 again and have noticed a very small puddle of transmission fluid right underneath where the linkage goes into the transmission. It is a side shift setup. Is there some sort of o-ring that goes in there that I can replace to stop the leak? I've never removed that part of the linkage before so I don't entirely know how it goes together. Any help would be great! Thanks!
-Chris |
Highland |
May 26 2013, 04:47 PM
Senior Member Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
check out this link. I have the same problem, but it's a small leak so I'm just going to change the seals the next time I change gear oil.
http://www.pelicanparts.com/techarticles/9...select_seal.htm |
Nor.Cal.914 |
May 26 2013, 05:09 PM
check out this link. I have the same problem, but it's a small leak so I'm just going to change the seals the next time I change gear oil. http://www.pelicanparts.com/techarticles/9...select_seal.htm Awesome! That is exactly what I was looking for, thanks! -Chris |
Nor.Cal.914 |
May 26 2013, 05:13 PM
I'm only seeing one seal that looks like it is for this fix...
http://www.pelicanparts.com/catalog/shopca..._pg2.htm#item13 Or are they both there and I'm missing something? Please let me know. Thanks! -Chris |
Highland |
May 26 2013, 07:40 PM
I think the other seal goes on top of the console and is part number 999-701-359-40-M30.
Here is the Pelican link with some figures: http://www.pelicanparts.com/cgi-bin/ksearc...-701-359-40-M30 I could be wrong though. I just see that it is a little bit wet above my shift console and I'm hoping this o-rig will fix it. |
mrbubblehead |
May 26 2013, 08:04 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
your both right, there is a seal AND an oring. the oring is 1mm x 40mm IIRC. i will double check when i look at my notes. you will have to do an oil change to replace them. the console sits below the oil level. its a pretty easy fix..... messy, but easy.
Mblizzard |
May 26 2013, 08:06 PM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
PM me I'd you want the 40 mm o-ring. I have 20 of the that are free if you need them.
mrbubblehead |
May 26 2013, 08:09 PM
20 was the minimum order when you only needed the one? LOL
mrholland2 |
May 26 2013, 10:29 PM
Senior Member Group: Members Posts: 753 Joined: 7-September 11 From: Santa Maria,CA Member No.: 13,531 Region Association: Central California |
There are two spots!
One is where the console goes into the trans and the other is where the fork shaft comes out of the console. . do both at once! It's very easy .. I'm in San Jose, let me know if you want a "straw boss" Sean |
Mblizzard |
May 27 2013, 05:19 AM
Nor.Cal.914 |
May 27 2013, 06:07 PM
Lo-Fi Version | Time is now: 26th June 2024 - 06:48 AM |
