 Forum Rules Classified Rules!
> 1970 willow green, beyond clean, restored and well sorted $18,795
sean_v8_914
post Jul 4 2013, 01:05 AM
Chingon 601
Joel has decided to sell Sweat Pea. the pea was created by Jerry M, a member here. Joel bought the car and we finished the details. we used lock washers, locktite and all the stuff that makes a car stay together. no duct tape, chewing gum or improvised fasteners. proper fasteners is my pet peeve/ fetish
3 Pages V  1 2 3 >
Replies(1 - 19)
sean_v8_914
post Jul 4 2013, 01:08 AM
Chingon 601
how do yous guys add long strings of images here? I can only get 2 at a time.
sean_v8_914
post Jul 4 2013, 01:11 AM
Chingon 601
just add fuel. you dont even have to wax it for a long time.
sean_v8_914
post Jul 4 2013, 01:13 AM
Chingon 601
pizza trunk
sean_v8_914
post Jul 4 2013, 01:19 AM
Chingon 601
here is a partial list. there are many more details to list
Suspension brakes wheel specs:
Front suspension and brakes: 911 T
Front suspension torsion bars: 18mm 911 type, stock red
Front suspension sway bar: 914/4 type 15mm stock
Front suspension bushings: stock rubber
Front suspension strut inserts: Bilstein sport yellow new
Rear suspension springs: 100 lbs Weltmeister SP100 black
Rear suspension shocks: Bilstein sport yellow new
Rear suspension sway bar: none
Rear suspension bushings: stock rubber
Wheels: Fuchs 16 x 6 polished lip, satin black center
Tires: BF Goodrich 205/ 50 R16
Master cylinder: ATE 19mm, new
Brake lines: ATE rubber, new
Engine and drive train specs
Pistons: 96mm flat top 8.5 to 1 compression
Crank shaft: 2.0 Porsche 71mm
Connecting rods: 2.0 Porsche
Cam shaft: webcam XXX custom grind
Cylinder heads: 2.0 Porsche 3 stud, rebuilt
Induction: New dual Weber 40 IDF carburetors, center pull linkage heim joints, Teflon lined Terry cable
Ignition: Bosch mechanical advance distributor with electronic trigger, Bosch blue coil BERU spark plug wires
Exhaust: SSI stainless steel heat exchangers, Bursch merged tuned 4-2-2-1 collector
Engine case: 1.5 quart low profile external sump
Fuel pump: front mounted Carter rotary type powered by factory fuel power circuit
Fuel lines: BMW 8mm CA ethanol fuel rating
Oil: Brad Penn 20-50
Transaxle: rebuilt 901 side shift conversion, new shift linkage and bushings, 90wt hypoid Valvoline VR-1
Rear transaxle mounts: upgraded 911 sport mounts
Starter motor: upgraded IMI Hi Torque gear driven with high current external solenoid
Interior specs
Morph interior panels
914rubber.com seals by Mark whitesel
pedal cluster by Bruce Stone
Steering wheel: 3 spoke Dino
Floor mats: Lloyds black with green 914 monogram
Seats: black with custom cloth center inserts, adjustable passenger seat
Seat belts: new retractable type
Entertainment: new stereo and Baupunkt speakers with IPOD and MP3 player
Door panels: custom 911 RS type
Pedal cluster: rebuilt, zinc plated, powder coated, silica-bronze bushing kit
Exterior, paint and body specs
Color: original L63k Willow green monochrome paint scheme
Side marker delete, antenna delete
Fresh weather strips rubber, door seals, bumper tops, body gaskets
New windsheild
Trophies, awards, featured on display, other
2011 San Diego International Auto Show “History of Porsche” Display, 3rd Place in Division 2011 PCA Zone 8 Concours d’ Elegance, Best Early German entry 2011 North Park Historical Society Auto Show, 1st Place in Division 2012 PCA Zone 8 Concours d’ Elegance, Currently registered as a CA Historic Vehicle.
124,000 original miles, “Full Restoration Driver” completed in 2011, less than 2000 mi since completion
sean_v8_914
post Jul 4 2013, 01:27 AM
Chingon 601
wires have grommets. cables are routed out of harms way and secure. cables have strain reliefs and chafing guards. fuel lines are routed outboard of the engine. fuel line junctions are below deck and away from the cooling fan and exhaust. cleaned relay board, chassis ground points, fuses, contacts and light sockets.
sean_v8_914
post Jul 4 2013, 01:31 AM
Chingon 601
new 2056 with new carbs and perfectly synchronized center pull linkage is coupled to freshly built 901 side shift gear box
sean_v8_914
post Jul 4 2013, 01:33 AM
Chingon 601
no rubs here
sean_v8_914
post Jul 4 2013, 01:37 AM
Chingon 601
drives better than a new 914. Dr Porsche would be proud.
sean_v8_914
post Jul 4 2013, 01:40 AM
Chingon 601
I should have wiped down the belly gear before I took the pics.
no hell in this hole
sean_v8_914
post Jul 4 2013, 01:44 AM
Chingon 601
Morph, Whitesell, Stone, camp914!
sean_v8_914
post Jul 4 2013, 01:46 AM
Chingon 601
green!
orthobiz
post Jul 4 2013, 09:17 PM
I need to stop looking at this car. Stop...looking...must...resist...
Seriously, this highly modded greenie is cool as hell!!!
Paul
BajaXJ92
post Jul 4 2013, 11:30 PM
Extended Member
(IMG:style_emoticons/default/wub.gif) (IMG:style_emoticons/default/wub.gif) (IMG:style_emoticons/default/wub.gif)
orthobiz
post Jul 5 2013, 05:40 AM
Can you show a closeup of the dash? I'm curious exactly how the color matching looks close up.
Thanks,
Paul
Niklas
post Jul 5 2013, 05:44 AM
Porsche 914 Sweden
Nice!
Maybe it should go to Sweden to me.... to me (IMG:style_emoticons/default/smile.gif)
Anyone know how to arrange the fright to Sweden ?
Is it the original colour ?
Niklas
orthobiz
post Jul 5 2013, 06:05 AM
QUOTE(Niklas @ Jul 5 2013, 07:44 AM) *
Nice!
Niklas
Yes original...
No Sweden!!! (IMG:style_emoticons/default/smile.gif)
Just kidding...
Paul
sean_v8_914
post Jul 5 2013, 09:18 AM
Chingon 601
this is the original color, l63k willow green.
non appearance group 914s had body color bumpers and no sail panel trim
sean_v8_914
post Jul 5 2013, 09:28 AM
Chingon 601
i am installing new retractable seat belts with inertia reels
there is no such thing as a 100% rust free 40 year old car but The sweet Pea is about as rust free as you can find anywhere
this image shows some surface rust. i have been thinking about finishing off this area if it does not sell. more green i think. i just dont want to disassemble since everything is so dialed in.
it takes less time to assemble than it does to dial in the details that make for a great driving experience
sean_v8_914
post Jul 5 2013, 09:31 AM
Chingon 601
the red stuff is 3m flange sealant. it follows the expansion and contraction difference between steel and aluminum. stays soft but impervious to automotive fluids. very expensive but never leaks
3 Pages V  1 2 3 >
- Lo-Fi Version Time is now: 1st April 2025 - 01:29 PM
