Battery cable size gauge |
Harpo |
Jul 8 2013, 05:51 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
What size/gauge wire do I need for battery cables? My current one is .35 inch in diameter including the insulation.
http://www.allenelectric.com/referencedata...rence_chart.htm This page suggests I need size 0. That seems rather large Thanks David |
Dave_Darling |
Jul 8 2013, 08:25 PM
914 Idiot Group: Members Posts: 15,067 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Mo biggah mo bettah.
Seriously, you want a large cable, because the starter draws a really ferocious amount of current. You also want sizeable ground cables. --DD |
Drums66 |
Jul 8 2013, 11:41 PM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
.....I second these comments! (IMG:style_emoticons/default/idea.gif)
(IMG:style_emoticons/default/bye1.gif) (IMG:style_emoticons/default/wolfgang.gif) (IMG:style_emoticons/default/robot.gif)(stronger) |
Cap'n Krusty |
Jul 8 2013, 11:54 PM
The ground cable should be larger than the positive cable.
The Cap'n |
Harpo |
Jul 9 2013, 03:46 AM
Thanks everyone
Retread |
Jul 9 2013, 01:36 PM
Newbie Group: Members Posts: 26 Joined: 5-March 06 Member No.: 5,672 |
[When doing a major engine out project on customer's cars I replace the stock cable to the starter with a 1 GA 60 inch cable. These are available from NAPA but will likely have to be ordered. Usually takes a day or two to get it.
I prefer the flat, braided heaviest ground cable NAPA sells i a 9 inch length. Please remember to clean the metal around the ground stud to ensure an excellent connection. These two components almost eliminate the need for the hot start relay kit. FWIW, cables need lots of strands. Most current is carried on the outer surface of a strand of wire. More strands = more surface area = less resistance. |
stugray |
Jul 9 2013, 06:08 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
QUOTE Most current is carried on the outer surface of a strand of wire. That is not true except for high frequency AC current. Solid wire would be much better in our cars, except stranded wire has better fatigue properties and is flexible. For my whole harness rebuild I used: 4Ga on - battery + to starter battery - to chassis battery to the front fuse panel. 10Ga from Alt to Battery (or to starter if you dont have a cutoff switch). And I have much longer runs because my battery goes through a master kill switch. I tried to use some of the tables that specify wire gauge vs rated current, and the wires were MUCH larger than the stock Porsche wiring harness. You have to take into account - Is the current intermittent (Starter) or continuous (headlights). If continuous, then the rating tables are closer, but: "what gauge is the wire that carries the current to the starter solenoid in the stock harness?" If you figure that out you will see that the Porsche engineers didnt use those tables either..... Stu |
Lo-Fi Version | Time is now: 4th January 2025 - 08:27 PM |
