freezing14 |
freezing14 ![]() ![]() Group: Members Posts: 435 Joined: 21-June 04 From: brockville , Ontario, Canada Member No.: 2,233 ![]() |
Ok got the frigging engine out because of those back fire,, remove the heads, , clean everything , lots of oil everywhere, and i do the compression test, here is the result
i did the test with 5 revolution on each , they all got the same result ( thats good) here my question 1st revolution 90 psi, 2 nd revolution 120 psi 3 rd revolution 155 psi 4 and 5 th revolution 155 is this ok , or do i need to change the rings or i am ready to (IMG:style_emoticons/default/driving.gif) |
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
R U doing the compression test with the engine warmed up?
Try squirting a little oil into the low cylinder and re test. If it stays down then you have a valve problem. ie -not seating or burning. Geoff |
scotty914 |
suby torque rules ![]() ![]() ![]() Group: Members Posts: 1,525 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 ![]() |
but before you do the test again do a valve adjust, and did you have the spark plugs out on all cylinders
and i though oil in the cylinders was for rings not valves |
freezing14 |
a little interpretation issue here
cylinder 1 revolution 1 90 psi rev 2 120 rev 3 150 rev 4-5 150 cylinder 2 revolution 1 90 psi rev 2 120 rev 3 150 rev 4-5 150 cylinder 3 revolution 1 90 psi rev 2 120 rev 3 150 rev 4-5 150 cylinder 4 revolution 1 90 psi rev 2 120 rev 3 150 rev 4-5 150 it says in the book with the compression tester that you need to use the same number of revolution testing |
Bleyseng |
So 150 on all cylinders thats great. Hmm, you running carbs? or FI.
scotty914 |
thats (IMG:style_emoticons/default/wub.gif)
put the motor in and (IMG:style_emoticons/default/driving.gif) |
freezing14 |
I will be running FI unless it buzz me off, then I wil carb it,
the 150 was acheived at the 3rd revolution so it would be ok , May be i can drive it before we have snow on the ground definitively,,,,, (IMG:style_emoticons/default/mueba.gif) |
Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,396 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
Also, did you test with the throttle at full open?? If not the numbers can vary due to not getting very much air into the chambers.....
freezing14 |
I did the test with no intake runner,,,, so would be considered as the throttle open??????, I just wanna made sure it was OK before I put it back togheter and in the car
Rhodes71/914 |
Glacier ![]() ![]() ![]() Group: Members Posts: 1,374 Joined: 8-August 04 From: End of the Road, Alaska Member No.: 2,482 ![]() |
I think you should be happy with those results. Put it in and drive before the snow flies. Wish I was at that point, couple of weeks maybe.
Lo-Fi Version | Time is now: 1st July 2024 - 12:04 AM |
