Front suspension sucks, Sways like a flag in a storm |
Mblizzard |
Aug 25 2013, 07:03 PM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
Well I think I have most of my engine sorted. Still some fine tuning on the carbs to go. But today when I was driving I noticed that at speed a slight back and forth motion of the wheel seems to set up a swaying pattern that could get out of control easily. To quote Jeremy Clarkson of Top Gear "at one point a little bit of poo came out."
I installed some used but still very good boge shocks. I have plans to replace the rubber bushings on the torsion bars but I am really concerned that something else is wrong. Nothing looks wrong but I am sure that the ball joints could be worn but I have never experienced that type of sway that seemed to want to get out of control. Thoughts on what to change or check? |
7275914911 |
Aug 25 2013, 07:06 PM
Hummmm!!! Group: Members Posts: 756 Joined: 7-May 08 From: Mid-South Member No.: 9,028 Region Association: South East States |
Steering Rack Bolts have come loose or come out? Can you turn the Steering wheel and the wheels not move?
Good Luck... |
r_towle |
Custom Member Group: Members Posts: 24,597 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Bearings.
Mblizzard |
Aug 25 2013, 07:11 PM
Mblizzard |
Aug 25 2013, 07:13 PM
Drums66 |
Aug 25 2013, 07:17 PM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
....Bearings as stated above or lug bolt torque (IMG:style_emoticons/default/idea.gif)
(IMG:style_emoticons/default/bye1.gif) |
r_towle |
Aug 25 2013, 07:19 PM
Jack up on front wheel, leave the other on the ground.
Grab the wheel at 3 and 9 o'clock. Wiggle side to side. If it wiggles, it could be tie rods. Grab the wheel at 12 and 6 o'clock Wiggle the wheel If it wiggles from the bottom, it could be the ball joint. If it wiggles from the top, it could be the upper strut bearing, or the strut itself. Do both front wheels this way, but remember one needs to be on the ground. Now the rear. One tire up in the air. Grab the tire and try to wiggle it in and out or front to back....you are checking the trailing arm bolt....see if you can move the wheel. Also, spin it and listen to the bearing. From that point I would suggest possibly an alignment. New tires And also check you steering linkage for play at the ujoints Rich |
Spoke |
Aug 25 2013, 07:21 PM
Jerry Group: Members Posts: 6,992 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Front end out of alignment may make the car seem to wander.
If the rear end is toe out it will make the car seem to get loose when turning in. |
Mblizzard |
Aug 25 2013, 07:24 PM
....Bearings as stated above or lug bolt torque (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/bye1.gif) OK I bite! Are you suggesting too little torque could allow the rims to move? |
Drums66 |
Aug 25 2013, 07:36 PM
......Yes.that body sway
(IMG:style_emoticons/default/bye1.gif)(frontend) |
Mblizzard |
Aug 25 2013, 07:48 PM
If that is it then a lot more poo will come out at some point! That is a scary thought. |
McMark |
Aug 25 2013, 08:44 PM
Also, the 'bushing' between the steering column and the rack may be worn out. (Black hockey puck in the video below)
Or the rack itself may be worn out. https://www.youtube.com/watch?v=ccihNmlBVoc |
FourBlades |
Aug 25 2013, 08:46 PM
From Wreck to Rockin Group: Members Posts: 2,055 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States |
Check everything in front and rear suspension and steering. More than one thing can be worn out or set wrong. John |
rhodyguy |
Aug 26 2013, 07:51 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,103 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
did the car do this prior to the boge install? too much horsepower now?(IMG:style_emoticons/default/wink.gif)
Mblizzard |
Aug 26 2013, 08:04 AM
did the car do this prior to the boge install? too much horsepower now?(IMG:style_emoticons/default/wink.gif) I wish! It had some slop in it that was noticeable but I thought it was the bushings. After driving it this weekend for a couple of days straight, it became apparent that there might be other issues. It just seems like it wants to hit a resonance and keep swaying. My other 914 had none of that! |
Shindog1961 |
Aug 26 2013, 09:33 PM
Member Group: Members Posts: 196 Joined: 10-November 12 From: Santa Fe New Mexico Member No.: 15,133 Region Association: Southwest Region |
Did anyone mention tie rods? Mine rolls a lot when they are loose.
HalfMoon |
Aug 26 2013, 09:52 PM
Senior Member Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region |
Front end out of alignment may make the car seem to wander. If the rear end is toe out it will make the car seem to get loose when turning in. Actually I had my car aligned today. It was toe out big time (and making it behave exactly as the original post described). Front end elignment corrected the problem but this post mentions correcting toe out in the rear. My mechanic today was wondering how you align the rear on 914's and frankly I didn't have an anwser. Could you enlighten? Where is the rear end alignment adjustment? Pictures would speak a gazzilion words :-) Tanx! |
Jeffs9146 |
Aug 26 2013, 10:54 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
When you loosen the 3 bolts that hold the out side of the trailing arm to the body you have a small amount of toe adjustment and the camber is done with the shims!
cwpeden |
Aug 26 2013, 11:10 PM
Great White North, huh? Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada |
WAIT! Warning before you get someone to attempt to align the rear. Take the plastic caps off the top of the bolt holes on the rear suspension mounts and put some pen. oil in there.
Took mine to get an alignment. They broke 2 of the bolts before they told me they weren't sure know how to do the alignment. Then said they would only charge me for the front end alignment. (IMG:style_emoticons/default/lol-2.gif) |
HalfMoon |
Aug 26 2013, 11:11 PM
When you loosen the 3 bolts that hold the out side of the trailing arm to the body you have a small amount of toe adjustment and the camber is done with the shims! Terrific! Thanks for that (IMG:style_emoticons/default/beer.gif) |
Lo-Fi Version | Time is now: 20th June 2024 - 09:18 AM |
