> plugs for heads, EGR tubes
qa1142
post Dec 12 2004, 01:42 PM
Whiplash
Anyone know what thread is on the tubes? I would like to just plug with set screws...
75 2.0L heads btw
Replies(1 - 9)
nebreitling
post Dec 12 2004, 01:46 PM
Member Emeritus
i don't know about the tubes themselves, but i capped my tubes with some caps i found in the plumbing section. NOT a standard pitch.
skline
post Dec 12 2004, 03:33 PM
Born to Drive
I think they were like .1.00 pitch. I went to the local flaps and got a bolt with the same thread for about .20 each and they fit perfectly. Holds the sheetmetal on also. Put your manifolds on after you put them in though. The manifold will sit right up against the head of the bolt to keep it from turning out.
Allan
post Dec 12 2004, 03:48 PM
Teenerless Weenie
10mm, 1.0 pitch, 50mm long.
94teener
post Dec 12 2004, 07:07 PM
Your use 10mm valve adjusting screws are ideal for plugging those ports, cheap too.
Phil
mattillac
post Dec 13 2004, 12:50 AM
robots!
weld the top of the tubes shut. or if you can't weld, pinch the tube closed by pounding it with a hammer, nice and flat. (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/smash.gif)
qa1142
post Dec 13 2004, 08:23 AM
Whiplash
10M set screws are $5.03 a box from McMaster Carr, I just needed the size
Thanks Team! (IMG:style_emoticons/default/beerchug.gif)
Cap'n Krusty
post Dec 13 2004, 12:36 PM
Cap'n Krusty
Just so you know, and the misinfo doesn't get spread, the EGR feeds into the aircleaner (intake), the tubes in the heads are for the air injection into the exhaust. They're 10x1mm, but the actual sealing surface is the ring on the injector tube itself. I've seen a lot of kludged plugs come out. The Cap'n
qa1142
post Dec 13 2004, 04:45 PM
Whiplash
are you sure they are 10M 1.0? Mcmaster only has 10M 1.5
www.mcmaster.com
92029A435
Metric 316 SS Cup Point Socket Set Screw M10 Size, 40mm Length, 1.5mm Pitch
Dr Evil
post Dec 13 2004, 04:54 PM
Send me your transmission!
go to your VW shop and pick them up. They are for 2.0L TIV engines.
- Lo-Fi Version Time is now: 22nd December 2024 - 06:20 AM
