mattillac |
robots! ![]() ![]() ![]() Group: Members Posts: 536 Joined: 27-October 04 From: vallejo,ca Member No.: 3,020 ![]() |
anybody heard of a V-TEC conversion for the 914. KEP could probably come up with an adapter if he doesn't have one already. but, will a front drive motor work with a rear drive tranny? does the crankshaft spin in the same direction? anyone hear of any other front drive engine conversions? my 914 deserves more power than i can afford to get out of my type 4 motor. for the cost of nickies and upright cooling and head work, etc. i could have a turbo vtec setup.
fire away... (IMG:style_emoticons/default/ar15.gif) |
dlo914 |
Whatchu' lookin' at?!?! ![]() ![]() ![]() ![]() Group: Members Posts: 3,432 Joined: 6-September 04 From: San Gabriel, CA Member No.: 2,697 ![]() |
(IMG:style_emoticons/default/mad.gif) ricer (IMG:style_emoticons/default/barf.gif)
lapuwali |
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 ![]() ![]() |
Many fwd engines do spin in the right direction, but Hondas are weird, and a lot of them spin the wrong way. This can still be fixed. One can use a 915 gearbox w/o flipping the diff, or you can flip the diff on a 914 gearbox.
The next step is figuring out if the engine will even clear everything in the engine bay. Some inline fours are too long to fit w/o lots of cutting. The turbo Soob engines fit well, and make lots of power. |
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
Blasphemizer!!! You'll roast in 914 hell for it!
Now that being said, there is (was?) a kit at KEP for such a swap, but you will have to get a 911 tranny, or flip the ring gear as the 4cyl Hon-duhs turn the other way (they're just funny that way). If you want more HP for less $$ and you want something unique that will enrage the purists, I have a corvair engine that will bolt up with less modification (IMG:style_emoticons/default/idea.gif) I have it rigged to turn the right way and to put out 170-180hp. What do you figure a V-Tech conversion would cost? Always double that amount. |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,440 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
Buy muellers engine adapter and all. Vr6 (IMG:style_emoticons/default/smilie_pokal.gif)
Dr Evil |
Muellers selling the VR6!? What happened?
sixnotfour |
Check the Classifieds
FS: '74 chassis, w/cage and sorted suspension bunch of pictures Mueller |
mattillac |
i thought a v-tec conversion would enrage the purists enough? guess i was wrong.
i like the v-tec cause its got a billion hop-up parts and lately i've been drooling over variable valve timing engines. |
soloracer |
Senior Member ![]() ![]() ![]() Group: Members Posts: 793 Joined: 7-April 03 From: Calgary Member No.: 538 ![]() |
A billion and one "bling bling - makah no power" parts you mean. I don't count turbo's as a special "hop up part" for a Honda because you can turbo any car. Most of the Honda stuff is relegated to bolt on headers, intakes, etc. If you are going to go turbo with an engine transplant stick to a motor that was turbo'd to begin with. Perhaps a 3SGTE from Toyota. I actually bought one for my 914 but sold it when I got my 20b. As for the whole Vtec thing - highly overated in my opinion. All you get is a little power surge in a small part of your powerband. Mostly marketing hype.
eeyore |
Senior Member ![]() ![]() ![]() Group: Members Posts: 889 Joined: 8-January 04 From: meridian, id Member No.: 1,533 Region Association: None ![]() |
It seems the money that isn't being figured is the conversion materials. Motor to motor a (stock) T4 sucks cost and power-wise against a V-TEC, but if you figure all the $$$ and time spent on installing said V-TEC, you'd be equal with a built T4, for less effort. Then there's the whole down-time component of converting to a different motor. blah, blah, blah...
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
QUOTE(mattillac @ Dec 15 2004, 01:09 PM) i thought a v-tec conversion would enrage the purists enough? guess i was wrong. i like the v-tec cause its got a billion hop-up parts and lately i've been drooling over variable valve timing engines. Sell your 14, buy a Honda and be happy! True sports cars were about handling as opposed to horsepower. |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
yep...VR6 engine and adapter are for sale (IMG:style_emoticons/default/smile.gif)....175 hp stock and you keep the car German powered (IMG:style_emoticons/default/smilie_flagge6.gif) (I'm going with a 2316 Type IV)
as said before, the 4 banger hondas turn the wrong direction (the V6 go the correct way), you are on your own for motor mounts and how to wire it up to your car to get it running...about the only thing you can use knowledge wise from other swaps is how to do the cooling (complete kits or Mickey Mouse Engineering (IMG:style_emoticons/default/smile.gif) ) |
soloracer |
That's too bad. I was hoping to see the VR6 install thread. The only Honda motor that I know of that goes the right direction is out of the S2000. But for the price of one of those you would be better off with a Porsche 6.
Mueller |
QUOTE(soloracer @ Dec 15 2004, 01:48 PM) That's too bad. I was hoping to see the VR6 install thread. The only Honda motor that I know of that goes the right direction is out of the S2000. But for the price of one of those you would be better off with a Porsche 6. I'm a little disappointed as well, but the more I thought about it, the VR6 engine swap would just be a novelty with no real value except bragging rights perhaps?? |
J P Stein |
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None ![]() |
QUOTE(SLITS @ Dec 15 2004, 12:27 PM) True sports cars were about handling as opposed to horsepower. Balderdash...... tell it to Ferrari. That was a line promougated by old European (mostly English) car fanatics who had (via tax laws) no horsepower to speak of. Oddly enuff, most all of these wankers worked real hard to get more power into these shitboxes. Horsepower is now and will always be.....glorius. (IMG:style_emoticons/default/biggrin.gif) |
mattillac |
VR6 = $$$. i'm leaning towards the honda because i have a few "hook-ups" for parts and engines. i agree with the bling bling parts, but the fact is that there is a wide selection of parts to choose from, and not all of it is bling bling. i don't think the v-tec is hype, its just a different way of squeezing horsepower out of a small engine. i'd probably wouldn't even go the turbo route if i got the v-tec, i'm just saying that to get a similar amount of power out of the type 4, i could have a turbo motor that would be smokin' that expensive type 4.
the motor mounts is something that would be a challenge though. and i was thinking about the 3sgte motor too. but, that 3sgte isn't all that cheap or easy to come by either. maybe an sr20det? oh i feel so ricer. (IMG:style_emoticons/default/headbang.gif) shame on me. |
soloracer |
You have to remember it's not just peak numbers that count. That is something that the Honda crowd has been sold on for years. Making 200 hp over 200 rpm is not useful for anything other than bragging rights. Take a look at the new Celica. A friend of mine bought one and it's a dog until the varible valve timing kicks in. He has to shift almost immediately after it hits though and then he's back out of his powerband. A stock 140 hp 13b RX7 from 1987 stayed with him all the way through the gears even though his car is advertised to have "190 hp".
I bought my 3SGTE for $1100 and sold it for $1300. They aren't that hard to find. A nissan engine would be nice - a member here has a Maxima engine in his 914. They make power the old fashioned way - displacement or forced induction. |
mattillac |
i wouldn't mind having the nissan motor, but again, cost and availability for me are the issues. it would probably be simpler to mount a RWD motor, but like i said i have good resources for the honda stuff. and i don't mind wringing my motor silly in order to make power. (IMG:style_emoticons/default/biggrin.gif) did you have any ideas on mounting the mr2 motor? i do work at a toyota dealer, so the 3sgte might not be that bad of an idea either.
anyone want to buy a 2.0 type4 with complete fi and alot of new parts? lemme know. |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,587 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Sung to the tune of "Ice Ice Baby" by Vanilla Ice.
"Rice Rice Baby...... Rice Rice Baby" Don't be a rice boy... if you gotta go conversion, go for the mega-HP. Put a 502 Chebbie Rat motor with a blower in a 914! Now that would be "overkill"..... (IMG:style_emoticons/default/lol2.gif) |
tat2dphreak |
stoya, stoya, stoya ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region ![]() ![]() |
I think: (IMG:style_emoticons/default/barf.gif)
Lo-Fi Version | Time is now: 25th June 2024 - 12:18 AM |
