trans removal |
trans removal |
Harpo |
Sep 22 2013, 02:09 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
I need to pull my trans. Do I have to pull the engine with it?
I believe that when I rebuilt my trans I may have put in an older differential. I have some slop in my output flanges that appear to be the result from not enough back lash on my differential bearings. Thanks David |
SirAndy |
Sep 22 2013, 02:13 PM
Resident German Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Do I have to pull the engine with it? No, but you will have to support the engine before you unbolt the transmission. (IMG:style_emoticons/default/smash.gif) |
Dave_Darling |
Sep 22 2013, 02:31 PM
914 Idiot Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Loosen the engine mount bolts so you can pivot the rear of the drivetrain down a few inches. You'll need to do that to clear the rear bodywork with the transmission. You'll also want to remove the muffler from the heat exchangers so you have enough room.
Some people use a jack to support the transmission when they disconnect it from the engine and pull it out; I just pull it out into my lap and support it with my feet and hands. It's not that heavy... Remember that at least one of the engine-trans fasteners is removed from the engine side, not the transmission side. And remember to disconnect the ground strap, in addition to the reverse light wires, starter wires, and clutch and speedo cables. --DD |
Harpo |
Sep 22 2013, 02:38 PM
Thanks guys
Cap'n Krusty |
Sep 22 2013, 09:51 PM
Before you do all that, better think about what you're doing. There's ALWAYS slop in the output flanges.
The Cap'n |
ruddyboys |
Sep 23 2013, 07:22 AM
Hummel eigentümer Group: Members Posts: 594 Joined: 3-March 04 From: Monroe, NY Member No.: 1,749 Region Association: North East States |
wouldn't it be easier to remove the engine and trans together?
ripper911 |
Sep 23 2013, 07:26 AM
corde pulsum tangite Group: Members Posts: 2,920 Joined: 25-April 10 From: Powder Springs, GA Member No.: 11,654 Region Association: South East States |
rjames |
Sep 23 2013, 10:00 AM
I'm made of metal Group: Members Posts: 3,996 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
CptTripps |
Sep 23 2013, 11:00 AM
:: Punch and Pie :: Group: Members Posts: 3,584 Joined: 26-December 04 From: Mentor, OH Member No.: 3,342 Region Association: Upper MidWest |
I did it in 30min on Saturday. Now, I have a V8 conversion so there isn't any exhaust in the way on mine, but it's a pretty simple process. Here's what I did.
1: Support the motor after you have the car jacked all the way up. 2: Disconnect Battery and ground strap at the back of the trans. 3: Disconnect and remove the starter. 4: Disconnect the shift linkage and Clutch cable. 5: Disconnect the axels. 6: Remove the 4 bolts connecting the trans to the motor. 7: Support the trans and then disconnect the rear trans supports. 8: Pull the trans back to clear the studs and drop it down. * Installation is the reverse. If you have muffler stuff...there'll likely be a few more steps, but that's how I did a "Trans Removal Without Dropping the Engine." |
Harpo |
Sep 23 2013, 04:44 PM
Harpo |
Sep 23 2013, 04:47 PM
Lo-Fi Version | Time is now: 26th June 2024 - 01:01 AM |
