Mblizzard |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States ![]() |
There have been a few items that I have encountered recently that just seemed very expensive for what they were. Getting closer to potentially getting them to a much cheaper price.
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Front suspension bushing?
--DD |
Mblizzard |
3-D printed Venturi's.
Thoughts? |
codices |
Member ![]() ![]() Group: Members Posts: 95 Joined: 9-October 08 From: Morrison, Colorado Member No.: 9,626 Region Association: Rocky Mountains ![]() |
These are tools for removal and replacement of small hub caps on factory teener wheels without bending or denting.
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,116 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
what are they made of? can the material handle a flash back thru the carbs?
Mblizzard |
Kevin they should be fine as the are high temp PLA with a melting point over 110 C.
r_towle |
Cool.
What materials can you print? I would be interested in some custom velocity stack. |
Mblizzard |
For the velocity stacks I would go with ABS lower melting temp but a little stronger material.
Right now we are mainly doing PLA and ABS. But we can do most extrudeable plastic. Let me know what you would like and we can either generate the or use your design. |
r_towle |
Is it just plastic?
Mblizzard |
Yep but it has an additional solvent resistant coating on it for fuels and and air flow. If there is a failure of the plastic due to heat, the impacts on the engine are quite small.
bulitt |
Achtzylinder ![]() ![]() ![]() ![]() Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States ![]() |
If I could offer a request, and don't know what volume you are talking about, but the front side marker assembly that holds the bulbs (not the lens) is NLA, Kinda thought about having a run of 1000 made up but possibly something you could offer.
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
r_towle |
Questin is really, can you only print plastic?
Mblizzard |
If I could offer a request, and don't know what volume you are talking about, but the front side marker assembly that holds the bulbs (not the lens) is NLA, Kinda thought about having a run of 1000 made up but possibly something you could offer. Being new to this I don't know all of the in's and outs but there are a number of places where you can essentially print whatever volume you want. But the printing capacity is not the valuable part. The STL file used to print the file holds the value. When you use one of the print on demand services you send that valuable file to them and it usually ends up in China before your part is done. That's just my impression and I could be wrong. If you have the file, the age and demand of this part makes it an unlikely target for others. The only problem would be incorporating the electrical connections. But certainly it can be done. While we don't have the file or capacity at this point we would be happy to work with you on this. |
Mblizzard |
Lo-Fi Version | Time is now: 26th June 2024 - 02:56 AM |
