Rod Bearing Tang Orientation, Rod Bearing Tang Orientation |
0396 |
Oct 4 2013, 11:39 PM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
Are the rods bearing ‘tangs’ supposed to be on the top or on the bottom of the rod?
I wonder if that makes any difference. Thanks in advance |
jimkelly |
Oct 5 2013, 06:43 AM
is there an indentation on top and bottom but only one tang per set?
(IMG:http://www.914world.com/bbs2/uploads/post-12268-1372885838_thumb.jpg) http://www.914world.com/bbs2/index.php?sho...3553&st=100 ask mrhyde |
0396 |
Oct 5 2013, 01:23 PM
Stock rods, both tangs on same side. Any advice is appreciated.
Thanks |
SLITS |
Oct 5 2013, 01:42 PM
That's the way they are intended to fit. The rod cap and the big end both have reliefs for the tang to locate the bearing. It won't make a difference whether the mating surfaces are up or down as long as the rod is installed correctly, and I don't remember if they are directional like some other engines are.
Once torqued into place, the big end of the rod places a "crush" on the shell to keep it where it is supposed to be. The most important thing is that the rods were resized to the correct diameter and that the cap and rod were marked. The marks line up with each other as that is the way they were torqued before machining. |
0396 |
Oct 5 2013, 02:24 PM
Slits...thanks for the education, I did line them up side to side ( numbered rod with same cap end) on same plane.
I ask because I remember some one posting on the bird site mentioning that years ago. |
Jake Raby |
Oct 5 2013, 04:49 PM
Engine Surgeon Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
This is why every build needs to be accompanied by my assembly video :-)
pilothyer |
Oct 6 2013, 12:46 AM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
This is why every build needs to be accompanied by my assembly video :-) Hello Jake.....Do you have a new rebuild video out ? The one I have is when you were just a youngster (IMG:style_emoticons/default/biggrin.gif) As surgeons generally go, their experience, knowledge base and wasteline gets bigger and better with age. I would buy one in a heartbeat if it is available....really need to buy one on DVD just in case the old VHS finally dies. |
Jake Raby |
Oct 6 2013, 05:13 AM
The video is 15 years old now... Though I've aged the assembly process for the T4 engine is still the same.
Lo-Fi Version | Time is now: 15th January 2025 - 03:13 AM |
