Looking for a 914 wheel size ET and tire chart |
wndsnd |
Nov 18 2013, 06:33 AM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
People throw tire and wheel sizes around but they usually dont show offset.
Does anyone know where I can find a dependable chart. |
jimkelly |
Nov 18 2013, 07:03 AM
see this
http://www.914world.com/bbs2/index.php?sho...;hl=wheel+chart and this http://members.rennlist.org/911pcars/WheelWts.html I love narrow body 5 lug cars (IMG:style_emoticons/default/wub.gif) |
wndsnd |
Nov 18 2013, 07:22 AM
Good Reading.
Thanks Jim. I am looking for that chart that is mentioned. If you happen to run upon it. Thanks |
wndsnd |
Nov 18 2013, 07:24 AM
The Rennlist chart is good, but does it always apply to 914's or just 911's?
Also would be nice to see tire sizes fitted without fender rolling, bending, etc. |
GeorgeRud |
Nov 18 2013, 08:10 AM
Seems there was enough variation from car to car and tire brand to tire brand that you really need to treat each application individually.
scott_in_nh |
Nov 18 2013, 08:47 AM
Senior Member Group: Members Posts: 808 Joined: 10-December 10 From: Hampton, NH Member No.: 12,471 Region Association: North East States |
John if the weather holds I can bring the car down and swap some tires around if you want to see how Mahles with 195/65's fit.
You could also borrow my steelies if you just need to get it on the road without paint burning tire rub. The tires on them are a little old, but I put 2k on them without any issues. |
Dave_Darling |
Nov 18 2013, 09:46 AM
914 Idiot Group: Members Posts: 14,992 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
There were only three sizes of wheels fitted to 914s originally, if you don't count the relative handful of M471 cars. There were 4.5"x15" (early "standard" steelies), 5.5"x14" (914-6 Fuchs only), and 5.5"x15" (all the rest). Offsets were pretty much the same in all of the 5.5"-wide wheels.
Since few people care about the 4.5" wheels, your 914 wheel offset chart would be pretty boring. That said, I don't remember the offset numbers. I do know that the backspacing for the 5.5" wheels is just about 5", though. The cars themselves have some variance, and the rear fender where the clearance is tightest can either be the left or the right--but it's always a rear fender. Most cars can fit 205s on the stock 5.5" wheels, but in some cases 195 is the limit. Wider wheels cause more problems than narrower ones; it is very difficult to fit 205s on 7" wheels under completely unmodified fenders. --DD |
jimkelly |
Nov 18 2013, 09:58 AM
fwiw
my 4 lug 15" sport steel have a 4.25 backspace I assumed this was about ideal for backspace I thought 4 lug fuchs were about 4.5 ?? jim Attached image(s) |
wndsnd |
Nov 18 2013, 04:36 PM
John if the weather holds I can bring the car down and swap some tires around if you want to see how Mahles with 195/65's fit. You could also borrow my steelies if you just need to get it on the road without paint burning tire rub. The tires on them are a little old, but I put 2k on them without any issues. Thanks Scott, It is on the road. Got the plates this morning. Drove it up to Exeter and around a bit. The car is a lot stiffer than I expected. I want you to drive it and tell me what you think.. The 195's that are on there were rubbing on one side, but since I made an adjustment to the camber I think that has reduced to just banging when the suspension hits bumps. But that is not frequent becuase everything is so stiff. I guess I expected the Bilsteins to be a little softer? But at this point stiff is good until I get the suspension sorted. I think I am going to go to 185's, and maybe different wheels. Right rear bearing is squealing and that pisses me off becuase I replaced it.. It was consistant at first, but now only in right hand turns. I am praying it will go away, but I know that it will have to get replaced again. Checked the brake discs and hub and there is no heat, which makes be think it is the bearing. Unless it is tire rub, but I have never equated that with a squeal. Picked up Al Romano and he helped me bleed the brakes once again, and now they feel good. The throttle is still not going back to an idle. Al gave me some pointers on adjusting the drop links and hex bar side play. The side play was affecting idle as well but now I might have it too tight. Contact me if you think you are coming to the area. I need good sugestions and advice. John |
wndsnd |
Nov 18 2013, 04:46 PM
There were only three sizes of wheels fitted to 914s originally, if you don't count the relative handful of M471 cars. There were 4.5"x15" (early "standard" steelies), 5.5"x14" (914-6 Fuchs only), and 5.5"x15" (all the rest). Offsets were pretty much the same in all of the 5.5"-wide wheels. Since few people care about the 4.5" wheels, your 914 wheel offset chart would be pretty boring. But offset changes between 15, 16, and 17's and also between widths? That said, I don't remember the offset numbers. I do know that the backspacing for the 5.5" wheels is just about 5", though. The cars themselves have some variance, and the rear fender where the clearance is tightest can either be the left or the right--but it's always a rear fender. Most cars can fit 205s on the stock 5.5" wheels, but in some cases 195 is the limit. Wider wheels cause more problems than narrower ones; it is very difficult to fit 205s on 7" wheels under completely unmodified fenders. --DD I am not even contemplating 195's anymore. I think I am going to 185"s, but I need to pick a wheel. I am unsure what the offset is on the EMPI's I purchased from the net, but supposedly they came off a 914. Maybe he had rub too... Don't know. But with the 195's I have less that 1/8 " and I have overinflated the tires, and induced as much camber as the car will allow to get the tires off the fender. |
wndsnd |
Nov 18 2013, 04:49 PM
Seems there was enough variation from car to car and tire brand to tire brand that you really need to treat each application individually. This I am sure is correct especially with me having removed 1/2 that fender and the complete door jam to get to the hell hole for repair. Who knows what might be off, I am too tired to measure everything (IMG:style_emoticons/default/yellowsleep[1].gif) |
Jeffs9146 |
Nov 18 2013, 05:00 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
Good Reading. Thanks Jim. I am looking for that chart that is mentioned. If you happen to run upon it. Thanks Wheel_Ident.doc ( 95k ) Number of downloads: 107 |
jimkelly |
Nov 18 2013, 06:15 PM
seems that 185x70x15 will keep your speedo accurate.\
I like the way 60 look better but my V8 hates them : ) if I ever get a suby conversion on the road, i'm going 50. http://www.914world.com/specs/tirecalc.php jim |
carr914 |
Nov 18 2013, 06:22 PM
Racer from Birth Group: Members Posts: 119,174 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
wndsnd |
Nov 18 2013, 07:10 PM
seems that 185x70x15 will keep your speedo accurate.\ I like the way 60 look better but my V8 hates them : ) if I ever get a suby conversion on the road, i'm going 50. http://www.914world.com/specs/tirecalc.php jim Got the console boot today. Very nice. |
wndsnd |
Nov 18 2013, 07:11 PM
scott_in_nh |
Nov 19 2013, 10:59 AM
I might be around this weekend John, I'll let you know.
Don't give up on the 195's, I bet you just have VW offset wheels that won't allow them to fit and my 195/65 on Mahles will not be an issue. The stiff ride is odd as everyone seems to love the Bilsteins and you only have the 100lb. springs (I have Konis set on full soft and 165 lb. springs and think the ride is great)... |
brant |
Nov 19 2013, 11:19 AM
914 Wizard Group: Members Posts: 11,641 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Shocks don't make a car stiff.... Springs do. And the stiction from not TRTproperly installed bushings can really contribute to spring rate
The 7R wheel on the chart is basically perfect offset and the reason a real 7r will fit. Of course a real 7r is 1k per a wheel. The 14 inch windmill that was stock on 6 cars was in my opinion used because it also has perfect offset. It is 2mm different than a 7r and a great fitment. It is also the cheapest fuch you can buy. It is also period correct. It will also give you a smoother ride as most tires available in 14 sizes have a taller sidewall. It also is a "deep" look wheel and cool looking. It does have down sizes. It is the least performance oriented due to the smaller diameter. Smaller width. And lack of tire selection. All of the 5bolt Fuchs and cookie cutters have the same offset and will fit an undamaged stock car |
mskala |
Nov 19 2013, 12:51 PM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
Shocks don't make a car stiff.... Springs do. And the stiction from not TRTproperly installed bushings can really contribute to spring rate The 7R wheel on the chart is basically perfect offset and the reason a real 7r will fit. Of course a real 7r is 1k per a wheel. The 14 inch windmill that was stock on 6 cars was in my opinion used because it also has perfect offset. It is 2mm different than a 7r and a great fitment. It is also the cheapest fuch you can buy. It is also period correct. It will also give you a smoother ride as most tires available in 14 sizes have a taller sidewall. It also is a "deep" look wheel and cool looking. It does have down sizes. It is the least performance oriented due to the smaller diameter. Smaller width. And lack of tire selection. All of the 5bolt Fuchs and cookie cutters have the same offset and will fit an undamaged stock car I am not aware of any 6x14" fuchs. There is 5.5x14" fuchs in other tables, offset is 41mm. I don't agree that 49mm offset of 7R is perfect, or even very good. However, if you like that, any of the following should also be useful: * 52mm, 6x15 phone dial * 52mm, 7x15 phone dial * 50mm, 6x16 early boxster I believe the best offset is 35-40mm. Keep in mind that all cars are a bit different. Also camber you are using (particularly in rear) is important. |
scott_in_nh |
Nov 19 2013, 01:38 PM
Shocks don't make a car stiff.... Springs do. And the stiction from not TRTproperly installed bushings can really contribute to spring rate I understand the functional difference between springs and shocks, but a shock with too much compression dampening will make the ride harsh when hitting a bump. One with too little rebound dampening could also be called harsh. Some folks might call a harsh ride "stiff". KYB wouldn't stand for "Kills Your Back" if they did not affect ride.... Your stiction theory sounds good as it addresses what I found "odd" |
Lo-Fi Version | Time is now: 18th June 2024 - 05:11 AM |
