azoldguy |
Newbie ![]() Group: Members Posts: 1 Joined: 20-November 13 From: Arizona Member No.: 16,680 Region Association: Southwest Region ![]() |
I managed to get my replacement seal into the side channels and lined up correctly across the top where the Targa top would slide in. I cannot get the "metal grippers" to grab the body flange and secure the seal. There must be a trick to it that I do not know. All suggestions are appreciated...and needed.
I'm looking forward to learning here in your forum. Thanks. |
Jeffs9146 |
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 ![]() |
I managed to get my replacement seal into the side channels and lined up correctly across the top where the Targa top would slide in. I cannot get the "metal grippers" to grab the body flange and secure the seal. There must be a trick to it that I do not know. All suggestions are appreciated...and needed. I'm looking forward to learning here in your forum. Thanks. I used a block of wood and carefully aligned the clips to the metal and tapped the wood block with a hammer to push the clips onto the metal! Don't force it just take it a bit at a time being very careful not to miss with the clips. |
r_towle |
I managed to get my replacement seal into the side channels and lined up correctly across the top where the Targa top would slide in. I cannot get the "metal grippers" to grab the body flange and secure the seal. There must be a trick to it that I do not know. All suggestions are appreciated...and needed. I'm looking forward to learning here in your forum. Thanks. Possibly the metal is wider than the flange? Vice Grips? |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
I just grabbed the seal and pushed. If you're close enough, you can also put the top on and the two front latches will pull the top forward as you hook them and push the seal forward the rest of the way.
--DD |
Chris Pincetich |
B-) ![]() ![]() ![]() ![]() Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California ![]() |
gothspeed |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None ![]() |
Lo-Fi Version | Time is now: 25th June 2024 - 11:04 PM |
