mbdoc |
Newbie ![]() Group: Members Posts: 24 Joined: 2-December 06 From: Lake Arrowhead CA Member No.: 7,298 ![]() |
1975 914/ 6
This car is apart and the chassis is at the body shop. Just some key items that go with this car. This car was assembled and in running conditioned. We put about 2K miles on it for a shake down and then taken apart to have the steel flares installed and painted. MOTOR: 1979 big valve 3.0 six. Engine has been rebuilt since shake down and has no time on it. We replaced the cams with new Web cams, reconditioned rockers by Web cam with new rocker shafts. Intake and exhaust valves are new SI swirl type. Valve springs are new to match camshaft. New Geotze rings. Engine has Redline EFI with tripple individual throttle bores. Has crank fire ignition by Clewitt Racing . Headers are thermal coated. Plug wires are Magnacore 8MM . Air filters are the foam ITG. OIL SYSTEM: Aluminum dry sump tank with all stainless hoses and AN fittings. Crankcase breather bottle made of aluminum. There is over 3k invested in just stainless lines and fittings. Dry sump tank mounts in the trunk and hoses routed thru the body. Has external oil cooler as well as factory oil cooler. External cooler is inner core swirl type. Has external oil temp thermostate. GEARBOX: Rebuilt side shifter. All bearings and sliders and syncros were replaced. J West shifter assembly. I have a spare gearbox to go with not sure of its condition though. Clutch and flywheel purchased from Patrick Racing. SUSPENSION: Five lug. Front brake calipers "S" type with vented discs. Front adjustable sway bar. Rear swings arms have been reinforced. Rear brakes are stock with e brakes. Front and rear adjustable coil over Bilstiens, revalved by Bilstien for the 914. Patrick Racing springs. Rear wheel bearings were replaced. 930 axles which were purchased new not rebuilt units. INTERIOR: Bolt in type roll bar made by Autopower. Quick disconnect Momo steering wheel. Optima battery with custom hold down plate. Master shut off switch for battery. The Sparco seat in any pictures you may view is NOT included. BODY: I have new steel flares and new lower hell hole panels. All purchased directly from Restoration Designs in Canada. The car is currently at the body shop to have them installed but not done as of yet. The sale of the car does NOT include the installation of the flares or ANY paint or body work. I have the seal for the upper windshield to top. This seal is no longer supplied, a very rare item. Pedal assembly has been rebuilt with bronze bushings. Mechanical oil temp and oil pressures gauges by Autometer. Front and rear fiberglass bumpers from Patrick Racing. I have all receipts for parts purchased. Buyer is responsible for all shipping or transportation costs. Please don’t waste my time or yours. No low ballers. No parting out, sold as described above. Thanks for Looking Adrian specializedservice@sbcglobal.net |
vinniedatorch |
Newbie ![]() Group: Members Posts: 40 Joined: 12-January 13 From: Lakewood Ca. Member No.: 15,358 Region Association: Southern California ![]() |
1975 914/ 6 This car is apart and the chassis is at the body shop. Just some key items that go with this car. This car was assembled and in running conditioned. We put about 2K miles on it for a shake down and then taken apart to have the steel flares installed and painted. MOTOR: 1979 big valve 3.0 six. Engine has been rebuilt since shake down and has no time on it. We replaced the cams with new Web cams, reconditioned rockers by Web cam with new rocker shafts. Intake and exhaust valves are new SI swirl type. Valve springs are new to match camshaft. New Geotze rings. Engine has Redline EFI with tripple individual throttle bores. Has crank fire ignition by Clewitt Racing . Headers are thermal coated. Plug wires are Magnacore 8MM . Air filters are the foam ITG. OIL SYSTEM: Aluminum dry sump tank with all stainless hoses and AN fittings. Crankcase breather bottle made of aluminum. There is over 3k invested in just stainless lines and fittings. Dry sump tank mounts in the trunk and hoses routed thru the body. Has external oil cooler as well as factory oil cooler. External cooler is inner core swirl type. Has external oil temp thermostate. GEARBOX: Rebuilt side shifter. All bearings and sliders and syncros were replaced. J West shifter assembly. I have a spare gearbox to go with not sure of its condition though. Clutch and flywheel purchased from Patrick Racing. SUSPENSION: Five lug. Front brake calipers "S" type with vented discs. Front adjustable sway bar. Rear swings arms have been reinforced. Rear brakes are stock with e brakes. Front and rear adjustable coil over Bilstiens, revalved by Bilstien for the 914. Patrick Racing springs. Rear wheel bearings were replaced. 930 axles which were purchased new not rebuilt units. INTERIOR: Bolt in type roll bar made by Autopower. Quick disconnect Momo steering wheel. Optima battery with custom hold down plate. Master shut off switch for battery. The Sparco seat in any pictures you may view is NOT included. BODY: I have new steel flares and new lower hell hole panels. All purchased directly from Restoration Designs in Canada. The car is currently at the body shop to have them installed but not done as of yet. The sale of the car does NOT include the installation of the flares or ANY paint or body work. I have the seal for the upper windshield to top. This seal is no longer supplied, a very rare item. Pedal assembly has been rebuilt with bronze bushings. Mechanical oil temp and oil pressures gauges by Autometer. Front and rear fiberglass bumpers from Patrick Racing. I have all receipts for parts purchased. Buyer is responsible for all shipping or transportation costs. Please don’t waste my time or yours. No low ballers. No parting out, sold as described above. Thanks for Looking Adrian specializedservice@sbcglobal.net PM sent |
drifter914 |
drifter914 ![]() ![]() Group: Members Posts: 50 Joined: 12-May 13 From: pearce, arizona 85625 Member No.: 15,863 Region Association: Southwest Region ![]() |
Hi Adrian... interested in the '75 914 project w/ 3.0 engine. Still available ? If so , I'd like a photo link & additional info. Very interested. Thanks. Terry / e-mail @ spayde1ranch@gmail.com
Evil914 |
Newbie ![]() Group: Members Posts: 46 Joined: 25-October 10 From: mineral wells,texas Member No.: 12,309 Region Association: Southwest Region ![]() |
Pictures sell cars
roblav1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region ![]() |
Did this car ever sell?
Lo-Fi Version | Time is now: 25th June 2024 - 08:02 PM |
