Trip Odometer reset knob, can anyone describe how it works? |
plas76targa |
Dec 30 2004, 07:08 PM
Senior Member Group: Members Posts: 885 Joined: 22-February 04 From: Frederick, MD Member No.: 1,700 Region Association: MidAtlantic Region |
I can't reset my trip odometer cause it's frozen. (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) I've pulled the speedometer and it's going in for refurbishment. I have the cable out and it's soaking in WD40. How's it supposed to work? Simply turning it to reset the trip OD ... or do you pull or push the knob (up or down) then turn it? Are replacement cables and knobs available?
Thanks, Matt |
bwilless |
Dec 30 2004, 07:14 PM
Member Group: Members Posts: 156 Joined: 24-January 03 From: Tempe, AZ Member No.: 192 |
You turn it. But don't turn it while driving, it will break your odometer. Ask me how I know.
Joe Ricard |
Dec 30 2004, 07:20 PM
The cable should turn pretty easy. it drives the gear on the trip odometer. Each of the numbers turns the one next to it until they all match and then you stop it at "0000".
plas76targa |
Dec 30 2004, 07:51 PM
Bwilless - thanks for the 'heads up' on don't reset it while driving. I'll try to avoid that once I get the speedometer back in the car.
Joe - With the speedometer and cable removed I can turn the numbers with the cable and they 'flip' exactly as you describe. My cable must be frozen just where it is attached to the dash board. I can't turn the cable/knob within the 'bolt' that holds the cable on the dash. Perhaps soaking it will clean out the crud in it. The PO had refurbished the car before selling it. He must have sanded the whole car prior to painting it. There is paint/sanding dust in every crevass of the car. I imagine it's this crud that has caused the trip odometer cable to be frozen. Anyone know where I can get a replacement cable? |
Lo-Fi Version | Time is now: 21st December 2024 - 10:49 AM |
