> 2 Post Lift Positioning, Just bought one and need some advice
dcheek
post Dec 25 2013, 04:42 PM
I just purchase and picked up a 2 post lift. It's an Atlas BP 8000 symmetrical lift. I have 27" on either side of the posts. I want to position as close to the front wall as possible, but still leave enough room to walk around the front of my 914. Any suggestions as to the distance from the post to the front wall ? My initial guestimate is 10 feet???
Dave
Replies(1 - 19)
brant
post Dec 25 2013, 05:04 PM
I think the 914 is about 14 foot
on my 2 post, the car is really just about centered with the post down the middle of the door when its up
so measure from the middle of your door to the front bumper is pretty close... I'd guess 7-8 foot?
TheCabinetmaker
post Dec 25 2013, 05:12 PM
I drive my car everyday
The post of mine is about 12 inches aft of the front of the door. Ten feet should be plenty. The car is only twelve feet long.
Eric_Shea
post Dec 25 2013, 05:32 PM
PMB Performance
From my experience installing ours, consider the center balancing point of the car to be loaded. As Brant states about the center if a 914. You would do yourself a disservice if you thought a 914 was all you might put on it.
Eric_Shea
post Dec 25 2013, 05:33 PM
PMB Performance
Also. Our cars are so light you could pretty much hang them anywhere on one if those lifts.
r_towle
post Dec 25 2013, 05:54 PM
Custom Member
Pick your longest car or truck and mount it for that....
dcheek
post Dec 25 2013, 06:33 PM
QUOTE(r_towle @ Dec 25 2013, 03:54 PM) *
My longest vehicle is a Vanagon, 180" or 15 feet. Divide that by 2 and that's 7 1/2 feet. If I add 1 1/2 feet, that comes to 9 feet away from the front wall. That should do it.
Dave
r_towle
post Dec 25 2013, 06:39 PM
Custom Member
You WILL be under a vanagon....
Woody
post Dec 25 2013, 08:32 PM
Sandbox Rabblerouser and head toilet scrubber
QUOTE(Eric_Shea @ Dec 25 2013, 05:32 PM) *
Very good point.
MMW
post Dec 25 2013, 09:18 PM
Below copied/pasted from Greg Smith website --(I'm sure other manufacturers have similar)
The Most Frequently Asked Question: How Far Should The Columns Be Set From The Front Wall?
If your lift has asymmetric arms, then we recommend the center of the columns should be set about 9-10 feet off the front wall. If your lift has symmetric arms, then we recommend that the center of your columns should be about 12 feet off the front wall.
If your lift has either the Atlas exclusive super symmetric arms or the versa-metric arms (found on the Atlas PV-10P), then we recommend to install the center of the lift columns about 10 feet off the front wall. The versatility of the above arms will allow the customer to "fudge" the position of the vehicle to allow the owner to walk around the front or back of the vehicle.
If a vehicle is to be asymmetrically positioned on the lift, then 30% of the vehicle will be in front of the columns and 70% of the vehicle will be positioned to the rear of the columns.
If your work bay is only 25 feet long, and the vehicle is 18 feet long, the front part of the vehicle will be about 4-5 feet in front of the columns. If your columns are about 9 feet from the front wall, you will have about 4 feet of space between the hood of the car and the front wall.
If the vehicle is to be symmetrically positioned on the lift, then 50% of the vehicle will be in front of the lift and 50% behind the column. If the vehicle is 18 feet long, then there will be about 3 feet between the front of the vehicle and the front wall.
Important Things To Consider:
•If you have a service bay that is 25 feet long and you are lifting a dually crew cab with an eight foot bed (total length of 23 feet)...you will have only one foot to spare from each end of the truck.
•If you weigh over 500 lbs., and your pant waist size is 67, then the three feet that you have allowed in front of the columns may not be adequate.
•If you have a $20,000.00 Snap-On ® tool box that is the size of a small home, you may need additional space between the front of the vehicle and the front wall.
•We would strongly recommend standing the columns up in your bay and then driving the longest vehicle that you think you would lift between the columns into a position that would allow the lift arms to reach the correct lifting points.
•If you can position this largest vehicle in a "safe" lifting position (and still have enough room to maneuver), then all smaller vehicles should be a piece of cake.
•When in doubt; let common sense prevail.
MMW
post Dec 25 2013, 09:20 PM
Dave please do a review on this when installed as I am looking at this lift & also the BP9000. Pics would be nice also.
euro911
post Dec 25 2013, 09:23 PM
QUOTE(r_towle @ Dec 25 2013, 05:39 PM) *
Eric_Shea
post Dec 25 2013, 10:54 PM
PMB Performance
QUOTE(dcheek @ Dec 25 2013, 05:33 PM) *
Dave
Yeah but, you may not want to balance a Vanagon in the middle.
KELTY360
post Dec 26 2013, 12:04 AM
914 Neferati
QUOTE(Eric_Shea @ Dec 25 2013, 08:54 PM) *
Dave
Amazingly, the Vanagon has almost 50/50 weight distribution.
euro911
post Dec 26 2013, 12:12 AM
It doesn't after you drop the drive train (IMG:style_emoticons/default/sad.gif)
Cairo94507
post Dec 26 2013, 09:10 AM
Michael
I sold my last house and 4-post lift and know I will be doing a lift in the new (to me) house. I do not believe that I will use a 4 post lift this time. I expect to be driving the Six instead of storing it. I just have not figured out if I want a 2 post or one of the in-ground scissor lifts. If I do a scissor lift I will have the garage concrete floor cut and excavated and the lift set into the floor so it is flush when down and easy to drive/walk over. When I get ready for that, probably a year from now, then I will get serious about searching for options and opinions.
rhodyguy
post Dec 26 2013, 09:49 AM
the greg smith site didn't open for me.
something to think about.
as i couldn't see the install requirements, what is recommended for the slab thickness? for an older floor that may have settled over time and has 'age' cracks there may be more work involved. like cutting out the slab where the posts will attach, excavating for NEW adequate thickness for the post anchors, cure time, possibly even the slope of the floor that most garages have. researching other 2 post lifts, the only ones i would consider, i found the 10' ceiling lifts more expensive than taller ones with the same lift capacity. i would not feel comfortable just drilling holes and using sleeved anchors for the posts either. threaded J-bots and some short pieces of of re-bar wire tied together, yes. not to mention the need for a stand alone 220v circuit.
MMW
post Dec 26 2013, 10:22 AM
The site opens fine for me. Here is the link.
http://www.gregsmithequipment.com/
patssle
post Dec 26 2013, 10:38 AM
I'm also looking at lifts for my 914 and Boxster - have any of you put a 986 Boxster on the BP8000 with no problem?
rhodyguy
post Dec 26 2013, 11:10 AM
finally opened for me, just slow i guess. very attractive price on the under 10' ceiling 2 post. shipping will prob kill. not all that much more than a scissor from HF. there may be some concrete cutting in my future. thanks for the greg smith mention!!
- Lo-Fi Version Time is now: 26th December 2024 - 06:43 PM
